Fixed my ABS/TC issues
Old Feb 22, 2011 | 08:02 PM
drivestwin's Avatar
drivestwin
Default Fixed my ABS/TC issues
After getting a light show on the dash when we hit a bump, I finally worked on the wheel speed sensor harnesses.
They came apart so easy, I thought the female plug might have lost tension and causing an open circuit when hitting a bump. Just a little twist of the male connector and reassembly was all it took.
Have driven it quite a bit in the last week, hitting every bump I could find and viola......no more problems.
Thanks so much for those of you who continually post your knowledge on what to look for and how to attack these things.
I know not all fixes are this easy, but just wanted to share my success and say thanks!!!
Marc
Old Feb 22, 2011 | 08:38 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Nice find and fix - most of the time it turns out to be much mire and a more involved job
I am glad it is fixed - good job
Thanks,Matt
Old Feb 22, 2011 | 09:01 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
nice score on the quick fix. try and remember it when you bust your knuckle on the next job
Old Feb 23, 2011 | 12:21 AM
ckhelm's Avatar
ckhelm
That's good to know! Mine came on after I hit a bump with the passenger front tire. Is this speed sensor harness easy to locate?
Old Feb 23, 2011 | 12:50 AM
00Corvette's Avatar
00Corvette
Thank Bill Curlee!
DZ
Old Feb 23, 2011 | 09:21 AM
drivestwin's Avatar
drivestwin
Default piece of cake to find
Yeah, piece of cake. Check your codes and it will point you in the direction of the offending corner. However I did all four just to make sure. The front harness can be fully removed and taken off the car. It hooks up to a female connector on the frame and a male on the hub assembly. The back is part of the car's harness and can not be removed. Just give them a quick twist, but not too much. When you reattach, you will notice they feel much more firm.
Worked for me......for now I suppose.
To Fixed my ABS/TC issues
