wideband plx afr and aeroforce gauges wiring help
I have the aeroforce gauges in an a piller mount. I am instaling a plx wideband. The plx I am wiring in the passengers side footwell for the hot on fuse 22 with an add a fuse. The aeroforce plugs into the obdII port for power and has a 3 wire adaptor coming off the gauges to wire to the plx. One wire is for power....which I believe I woulldn't use at all , One wire is for analog 1 and the other is for analog 2. Do you just wire one of the analog wires from the aeroforce 3 wire harness to the wideband quick connect on the plx? I am a little lost on hooking up the two units to work together. Any advise would be helpful
http://www.plxdevices.com/Installati...UsersGuide.pdf
Jim
Jim
