How to change a/c blower motor ?
fan easy to get to but tough to get out
The trick is to have magnetic tipped screw divers or nut holders. The carpets and duct work are easy three nuts are not! take the one closeat to firewall first. Then loosen the connector and small hose. The other two are a piece of cake by comparison . Clean the cage and spray a bit of silicone into it and then hook it up to see if it works-mine had a ton of junk in it! I cleaned and put back in, running like it just left the factory!!!. Started with back nut first since you have more energy and patience at that point. It is tough but once done, great feeling.
