How-To repair EBCM avoiding costly repairs through ABSfixer or Fleabay
#61
#63
This is awesome for you later model guys!
Wish it were that easy with the 1997 - 2000
Thanks,Matt
Thanks,Matt
#65
Just completed this a few minutes ago on my '02. I just re-flowed the solder (with some new) on the existing relay. After clearing all the historical codes, no new ones are returning.
I didn't have a clear understanding of that hole in the cover until I got mine apart. It is a 1/8" passage through the shell to the front plate - you cannot hit a circuit board even if you wanted to. I used a Craftsman 1/8" punch, set the closest beveled mounting ear on a bench vise, and kept hammering until the sound changed indicating that the bead had broken. Then screwdrivers all around to finish separating the silicone.
An alternative to the punch would be a self-tapping screw that has a minor diameter of around 1/8" to get a good bite. Sorry I don't have an exact dimension, but hopefully this helps.
I second the comments by blackdak318 to get a hot iron. I had a little pointy 15W that worked on the smaller terminals, but didn't have enough oomph to melt the large center lug. The old 120W gun made short work of it.
I also pass my thanks on to all the contributors here. This forum is invaluable.
Todd
Picture of my 1/8 punch in the hole.
Todd
#66
I pulled mine out of my 03 ZO6 and sent it to someone I found on Ebay. They fixed it for $50 and I didn't have to pull it apart. It's been working perfectly for the last two years.
#68
Todd
Todd
#69
Here's a pic I took before my repair, and have zoomed in on two of the terminals in question. You can see it in the OP's 3rd pic too, on the relay center terminal. It appears as if a rift/ridge barrier has formed between the post & the circuit board it should be connected to. Re-melting the solder and adding some new took care of my C1242. As Lucky said above, "a classic case of insufficient solder/cold solder joints". Not sure exactly which it is (because all of my solder joints have never looked like this ), but clearly the solder is not doing it's job of connecting part A to part B. My worst looking terminals were on the load-side of the relay. Perhaps high current, vibration, and repetition along with lack of solder are a formula for this type of failure. Clearly the joints did work for 7+ years before failing, and mine was intermittent for several months before going consistent.
Todd
#70
Todd
#73
#74
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
TTT
#75
Thanks to all who've attempted this, if it weren't for you guys I wouldn't be as sure of this fix as I am now. Of course there isn't any issue with mine, but it certainly helps to see so many follow this write and clear codes permanently.
#78
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Short answer,,,, no
#79
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Long answer,, Its a completely different EBTCM. Do you have a front or rear mounted EBTCM??
Rear Mount =
BC
Rear Mount =
BC
