drive shaft bolt upgrade????? 10mm to 12mm or just get High strength aircraft bolts ?
Hey guys need to do some drive train work. RnR clutch etc. while I am there want to do the drive shaft rubber u joints and replace the bolts
ARP make anything for the old 10mm bolts or should i get a specific high grade bolts?
or....drill and tap and put in 12mm and larger rubber u joints?
what you guys think... FYI I am not rich
The strength of the OEM fasteners is more than adequate. I do not believe you will gain much stength and reliability with the modifications you are considering, you may even reduce it.
The best solution in my opinion would be replace your existing drive line with a complete used 2001 & up torque tube and propeller shaft assembly.
I never heard of anybody breaking bolts, only propshafts twisting or couplers falling apart.
I have seen two different style poly couplings. One from the Driveshaft shop and one from Prothane (I think).
The Driveshaft Shop one is a big round poly donut with metal sleeves and the Prothane one is an aluminum donut with poly bushings inserted into the aluminum with sleeves on the inside.
Neither is exactly cheap, but the Driveshaft one I have seen in numerous car build ups in magazines including several big horspower cars (1000 hp). The Prothane one is unproven in my mind. It may be just as strong. I haven't heard of anybody using that one so I can't really say.
I have both sitting on a shelf somewhere. I'll post a pic later.
^ I've sheered the front coupler 10mm bolts right off. But I was running 650RW+ and shifting HARD. And mind you this was after years of hard driving and abuse.
Unless you are running huge power and tracking a great deal the stock 10mm parts should work just fine. Throw in some new couplers and call it a day.
Two styles of polyurethane couplers and neither is exactly cheap:
http://forums.corvetteforum.com/album.php?albumid=18158
we did have one guy sheer the 10mm bolts with about 450 rwhp
but they were stressed from a previous failed donut
P.S. 10mm
I was thinking about that... I am guessing the stock bolts are not Grade 8?
Also I was considering high grade aviation bolts because they have very high sheer strength. do not where to find them though
The difference in the two versions is more than just a different diameter bolt being used in the couplers. The later model torque tube assemblies have a larger diameter driveshaft as well.
Hardly a huge increase. Maybe their engineers just wanted to make the drive shaft/torque-tube stronger for no good reason. Perhaps they should have just let well enough alone since there were no failures being experienced on the "10mm" driveshafts to the best of my knowledge.
I guess I mistakenly thought you were going to be modifying your power levels, or at least had intentions of doing so in the future. If you are not, then just get the stock GM 10mm couplers and not spend extra on drilling out bolt holes and re-threading, etc when it's something not needed on a stock setup.
10mm bolts
I think arp makes a 10mm bolts in 5 packs
Does anyone know the dimensions and tread of the stock 10mm bolts
I wanna order some for my set up
