Greyish smoke from exhayst only at idle...
lucky,
what ive done was simply pulled the pcv valve and vented the crankcase vapor temporarily to atmosphere. similar to an oil cap with a breather, and capped the intake manifold vac. line. only at idle, just to see if it were a PCV (over) flow issue or to see if it were oil vapor im seeing out the exhaust.
I take pride in working on my vehicles and not throwing in the towel to a shop unless it's beyond me. Hopefully, sooner or later my knowledge and technical advice will truimph over an unnecessary dealership visit. if i can isolate it as a tune issue, I'm going to have ECS tune the car.
Good luck.
