home made glass-pack exhaust
#42
I actually had a kid I grew up with tell me to put glass packs on mine, but they'll burn out at, yea it may be loud as hell but it'll be so raspy and not smooth. You don't want that. Lol
#43
http://cgi.ebay.com/ebaymotors/BORLA...ht_6526wt_1025
#44
you were talking earlier about borlas was this like what you meant?
http://www.corvettegarage.com/produc...-corvette.html
I run em with my dynatechs it's nice and loud. Take the cats out and cam it, dannngggg lol
#45
Tried running my GMC pickup without the O2 sensors, absolutley NO power. signal to ecm created a extreme rich or lean condition, cant remember. Anyways then I tried to just take the Cat. Converter off, ran so bad couldnt even get out of the driveway! The only way to do these mods. is to completely reset the ecm, or go old school and eliminate the ecm.
#46
Received 3,812 Likes
St. Jude Donor '03-'04
#49
Put some spacer/s between the midpipe/over the axel pipe joint and use some longer bolts.
It will leave a gap between the pipes and allow you to see what a MUFFLER LESS C5 sounds like without spending a LOT of cash. I used some longer bolts and some large nuts as spacers. It is LOUD but the sound to me was a bit crude and gutteral.
if you want straight pipes, pull the mufflers and weld a pipe between the exhaust tips and the over axel pipe .. I think MercuryMike had a tip to do that back in the day.
