Dealership suggested fuel injection clean... Worth it?
As the title says... their mechanic recommended their throttle body and fuel injection cleaning service (I had it in for another issue). Is this a worthwhile service to pay for or is it just a upsell service with little real value? My car is a 2000 6-speed with 105k miles.
I think it's SEAFOAM that many recommend. CRC makes aerosol products which clean the MAF and throttle body. About $25-30 of products and an afternoon of your time and you might be able to accomplish the same thing.
The site I posted also removes the tiny screens on the inlet and installs new ones, flow tests them before and after and posts the results on their website-they come back looking and working like new for about the price of 1 new injector.
We clean throttle bodies because of a coking condition that builds on the throttle plate edge and the contact area of the throttle body over time.This messes up the min airflow,which isnt adjustable and causes low speed idle and stalling problems.To simply clean your injectors Seafoam will work just fine.
But that does not apply to our throttle bodies, since coking is a build up of unburnt fuel/oil, and the fuel on an LS motor is directly injected into the cylinders.
I buy gas with Techron 100% of the time and at 89,000 miles have no issues. I pulled my manifold to change oil pressure sensor and looked at injector tips they looked new.
Wounded Warrior Escort '11
A couple of years ago, I had my injectors tested. They came out better spray patterns than new injectors and no leaking whatsoever. Pretty sure this was ar or near the 300K miles on the clock. I normally ran a bottle of techron through it once every 6 months.
AKA "The CLOWN"
Put 2 gal of Xylene with a fill up of 93 and run WOT. your internals will all be spotless and the car will run better!
Or get Alkey Meth kit on your car, but not needed unless your boosted!
......interesting.
Can I pick it up at Home Depot, Ace Hardware, Paint store......?
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Xylene is used as a solvent. In this application, the mixture of isomers is often referred to as xylenes or xylol. Solvent xylene often contains a small percentage of ethylbenzene. Like the individual isomers, the mixture is colorless, sweet-smelling, and highly flammable. Areas of application include printing, rubber, and leather industries. It is a common component of ink, rubber, adhesive,[6] and leather industries. In thinning paints and varnishes, it can be substituted for toluene where slower drying is desired. Similarly it is a cleaning agent, e.g., for steel, silicon wafers, and chips.
......interesting.
......interesting.
