What size is the bolt for the dipstick tube?
I just put my headers on my 99 FRC and I went to the late model dipstick tube that bolts to the head instead of the manifold. It didn't come with a bolt. What is the bolt size for the head?
I am wondering this too as I need to bolt mine down after XS Power headers. What brand did you install?
My parts manual shows the dipstick tube part number changed for 2001 MY, but the bolt part number is the same from 97-01.
The bolt from the hold manifolds is a tiny bolt that is far too small. I also tried the bolts from the AIR tube where it connects to the manifold, and they are also too small. I don't want to find out by trial and error with aluminum heads.
I'll have to look closer tonight then. Maybe I'm trying to screw it into the wrong hole. I know people have done this before, so I assume the head castings didn't change where the new ones have different holes. It's amazing that the most mentally challenging part of the long tube header install is the stupid dipstick hold-down bolt.
I don't know what size it is, but I used one of the bolts from the stock H-pipe to bell housing bracket that I'm no longer using, and it fit perfectly in the head. The head of the bolt is 15mm.
