Age of Goodyear Eagle Supercar F1 tires
Old 11-18-2011, 03:01 PM
quick04Z06
CF Senior Member
quick04Z06's Avatar
Default Age of Goodyear Eagle Supercar F1 tires
How can I tell the age of these tires? I have found a set that look to be in great condition but I cannot tell how long they've been "sitting around." Any suggestions?
quick04Z06 is offline
Old 11-18-2011, 03:10 PM
87SAM
CF Senior Member
87SAM's Avatar
87SAM is offline
Old 11-18-2011, 04:28 PM
quick04Z06
CF Senior Member
quick04Z06's Avatar
Old 01-30-2012, 04:13 AM
kimbo305
Junior Member
I was aware of the DOT tire manufacture date codes, but for the life of me, I couldn't find them on my F1 Supercars anywhere!
All 4 are mounted with the right side facing outwards. I found this picture online of a Supercar tire:
http://www.productwiki.com/upload/im...1_supercar.jpg
And I can plainly make out the DOT code. But I swear that isn't there on my version of the tire. I'm so spooked I'm gonna go check tomorrow. I was checking at night in a gas station so maybe I missed it.
kimbo305 is offline
Old 01-30-2012, 07:36 AM
kmetros
CF Senior Member
kmetros's Avatar
They aren't always on the outside. I haven't figured that part out yet, but even directional tires don't always seem to have them on the same side.
I'm not a fan of tires more than 5 years old, especially on a Corvette. Don't just go by looks - just because there are no cracks in the rubber doesn't mean that the compound is the same as it was when it left the factory. It is definitively harder and has less traction. Period. You may not notice it in a straight line, but if they break loose easily or if the car doesn't seem as stable around turns I'd consider looking at swapping them out.
It's not so much just driving around on 5 year old tires that should concern you it's potentially NOT having control during evasive maneuvering / stopping that is the reason you should always consider updating 'older' rubber.
Kurt
kmetros is offline
Old 01-31-2012, 12:31 AM
kimbo305
Junior Member
I thought even if the full code isn't on one side, then there still needs to be a DOT mark on it? I can't even find that.
How many generations of Eagle F1 Supercar have there been? Just 2, I thought. Mine look like the first gen model as shown on Tirerack:
http://www.tirerack.com/tires/BigPic...le+F1+Supercar
Pardon the rotor rust -- I haven't driven it in a week. Hard in the middle of Boston winter.
https://lh4.googleusercontent.com/-u...hoto%25204.JPG
https://lh5.googleusercontent.com/-O...hoto%25203.JPG
https://lh5.googleusercontent.com/-1...hoto%25202.JPG
https://lh3.googleusercontent.com/-3...hoto%25201.JPG
What I've tried to do is take a few shots of the tire at the place where I expect the DOT marker to be, based on where it is in the Tirerack image, judging relative to the placement of the word "Supercar."
There's just nothing like it on my tires. I checked all 4. And unless I'm nuts, I think they're facing outward and properly mounted. Maybet it's still a different version of the tire?
kimbo305 is offline
Old 01-31-2012, 08:17 PM
kimbo305
Junior Member
Here's two full shots of the front and rear on the right.
http://i.imgur.com/jbzML.jpg
http://i.imgur.com/86ukH.jpg
You can see the mark that says this side faces out. But no DOT code.
kimbo305 is offline
Old 12-19-2017, 08:45 AM
405 Bald Eagles
Junior Member
Digging this thread up from the dead....
Looking at used Z06 w/F1s and I have no idea if they're original or not. Like the originator of this thread, I can't find a 4 digit date code anywhere! There's a 6 digit code below the "R" in Goodyear but I don't think that's it. Guess I'll be calling Goodyear customer service.
405 Bald Eagles is offline
Old 12-19-2017, 10:52 AM
vettenuts
CF Senior Member
vettenuts's Avatar
You need to look at both sides of the tire. On my motorhome, most face the inside so I need to crawl under to see them.
vettenuts is offline
Old 12-20-2017, 12:46 PM
Red Dwarf
CF Senior Member
Red Dwarf's Avatar
Kurt
Great advice!
Red Dwarf is offline
Quick Reply: Age of Goodyear Eagle Supercar F1 tires
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
