Rear-gear Swap/Differential Rebuild How-To
1/4 mile/AutoX
I also want to change my rear gears myself,have had the same it's too hard for you !!!! I have 20 some years of GM Dealership experience (tech) and have a lot of those special tools !!!!! How did you decide what ratio to go to ?? I was thinking (I have 3.42) of going with 3.73 or 3.90 !!
Along with the rest of the praise you received here I also am impressed, the amount of time and effort is amazing !!!! Thank you very much !!!!
Only reason to go 3.90 is if you have a blown or nitrous car that can trap higher than 135 in the ¼ mile, if you have that much power, you'll be shifting to 5th before the stripe.
Pounder (12-16-2015)
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
MAN,,,,,,,,,,,,,,, You have outdone yourself with this post. I thought the Differential Up-Grade post was good.
WOW!!!
EXCELLENT WORK!
Bill C
WOW!!!
EXCELLENT WORK!
Bill C
1/4 mile/AutoX
Yes, I know this is an old thread. I found it because it has information I'm looking for.
This guy needs to be commended. The man made his own tools when he could clearly afford to just go buy them. Unreal. That is so cool. What an inspiration.
One of the best how to threads on this forum.
Word to the wise who want to keep this wonderful information... I printed it to a PDF.
Pictures and even entire threads can disappear from the Forum without notice or trace. This is too good to lose!
Thanks again Its_Go_Time for this wonderful thread and taking your valuable time to help your fellow Vette enthusiasts.
I've got a dilemma. Need the clutch packs in my differential replaced, contacted a shop that was highly recommended, says he does these all the time, told me his bill of material and said the LH pack is different then the RH pack. I had looked into doing this myself, but can't. All the parts lists I've read including the GM parts dept says the RH and LH is the same part number. This guy says no, they are different. Now I'm not sure if I want him doing the job.
What's your feeling?
It's really not a tough job to do yourself, but if that's not your cup of tea are you able to remove the differential on your own? I would send it off to RKT or RPM and never second guess the quality of the work.
Good luck!
Tim
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Some of the online parts diagrams show two different item numbers for the LH vs RH clutch pack (tonkin online) but the underlying part number is the same. That may be the issue with your guy. Get the C6Z belleville springs. Yours will be broken as all C5 belleville springs broke when the cars were driven out of the factory ;-)
Good luck!
Tim
Good luck!
Tim
Tim,,, I agree 100% I ordered my C6 Upgrade parts from Gene Culley and BOTH clutch packs came in a box. NEITHER ONE wa any different than the other. They were interchangable side to side.
Your mechanic is not accurate. YES,, The C6 ZO6 Spring is superior to the C5 CRAP. IF,, you have to have the clutch packs and springs replaced, PLEASE do your self a favor and also purchase the C6 UpGraded output shafts. 1000000% better than the C5 OEM crap.
Here are TWO outstanding post that detail whats all about the up-grade and how simple it is:
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
IRON MAIDEN (04-04-2017)
Good luck!
Tim
Good luck!
Tim
This guy said he does plenty of these rebuilds and argued that the clutch packs were different between sides. I asked why does it only give one part number and says two required, he didn't answer.
He also said I would probably need new bearings. OK by me ,while you're in there.
I used to have a lift and did all my own stuff, but since I moved and only have a garage floor and jack stands, at 66, I don't feel I would be able to pull the differential. He wants $1,600 to do the job, sounds really high to me.
Like I said, he was referred by several people on the forum. He only works on vettes.
#33
Thank you for your input.
#34
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The clutch packs are the same on both sides, he is wrong on that point. If your are not comfortable with this shop then it sounds like your other route would be to call RPM or RKT and arrange an exchange (call them either way, discuss your situation and get thier advice). Have a different shop do the labor to swap the differential. Might not be any less money but your confidence has value. Tough spot...
Unless the bearings are bad (probably NOT), they DO NOT need to be replaced. Infact, adding all the improved parts does NOTHING to disturb the differential set up/alignment. Add the new parts and drive happy..
#35
sub'd
thundertruck (03-17-2018)
#39
Is that extension safe to use? Recent reviews are not too favorable.
14 reviews for this add-on
This extension secretly adds the author's affiliate link to all Amazon URLs. They did the same thing with the Chrome version of this extension (until they were called out) and likely with the Opera version as well.
Rated 1 out of 5
by Anonymous user 9c1201, 4 days ago
Doesn't work anymore. Guess they beat the script again. 3/10/18
Rated 1 out of 5
by Anonymous user 3557d5, 7 days ago
I'm not a computer genius by any stretch of the imagination, so if I am misunderstanding the ratings, please enlighten me. Looks like photobucket is waging war with it's users, and we are collateral damage.
Rated 1 out of 5
Rated 1 out of 5
