Pro products Typhoon Intake Manifold Opinion help
Any opinion on the Pro products Typhoon Intake Manifold??
LS1 LS6 Polished Finish, 96mm Inlet
eBay 280436696805
http://www.ebay.com/itm/New-Pro-prod...item414b5466e5
I have a 2001 C5 looking to upgrade..
I need the following;
- Intake
- Headers
- Cam
Trying to keep in a budget...
eBay 280436696805
- Intake
- Headers
- Cam
eBay 280436696805
- Intake
- Headers
- Cam
eBay 280436696805
- Intake
- Headers
- Cam
I have no knowledge of the PRO PRODUCTS manifolds for the LSx motors other than what I've read here many times...heavy, heat soaking, blingy.
I know from friends who used PRO PRODUCTS manifolds on their modified tri five Chevy cars though. They're made off shore. They leak. Correct fitment/machining was iffy. Their attention to tolerances left much to be desired.
From my personal experience with their inline fuel filters...they all leaked. For the money I saved by buying their products, I wasted when I had to buy what I should have bought in the first place.
AKA "The CLOWN"
I just bought this off a friend of mine that had it on his car for 2 years with no leaks and great fitment. When these first came out in 05-06, there were some that leaked, but the company has since corrected the issue.
I chose to add this to my set up as it comes with bigger fuel rails that I needed anyway. The plate on the underside has been ceramic coated to help with heat soak and this intake out flows the LS6, Weind, and BBK, the FAST does flow a bit better. I don't really care, I like the sharp looks of it and its different. The stock intake and the FAST look like cheap crap!
It is simply badass and a lot cheaper than a fast!
do a lot of research on here, you already have a LS6 intake since yours is an 01. people here are running 500+hp on the same intake you have now. Combine the reported fitment issues with the FAST 102, the fact it is going to be well over 1K dollars to buy the intake and throttle body and you will gain maybe 15hp after tuning. You could take that grand and put a good set of heads on the engine while doing the cam swap and gain more than what the fast alone would have given you without the heads. as far as the best header, beaten to death time and time again. you really cant go wrong with any of the popular brands, TSP, XSpower, LG, Kooks. They apparently dyno within a few hp of each other but fitment can be different. My 700 dollar TSPs dropped right in with no issues. Others require you to raise the engine off the mounts. Your call.
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
AKA "The CLOWN"
Lets go in the middle and say 20rwhp gain!
It's going to cost you $1000 to buy and install one
I don't mean to offend anyone!
But $1000 for 20hp! That is "JUST STUPID"
I have over 600hp at the wheels, I did not buy the Typhoon for gains, I did it because it looks bad *** and I need bigger fuel rails! Sorry!!!
