C1222 post jacking up the car real high on the driver side
I needed to do some heat shielding by my driver side turbo. I had to jack my car up pretty high due to my physical side to be able to get my hands where I needed them. I use to get C1233 intermittently, but once I was done I took the car for a spin and I immediately got C1222 just backing out of my driveway. I reset it and it came right back in seconds. Could it be the wheel hub bearings? I replaced the wheel sensor cable a month ago on both sides.
Vince, the difinition of an OBD11 error code C1222 is: current = "C"
1222 = "wheel speed mismatch". Wheel speed/car speed don't match.
C1222 H - RF Wheel Speed Sensor Input Signal is 0
I am more curious to why? I use to get c1233 daily and then after jacking one side of the car up I am now getting C1222 instantly after rolling backwards or rolling forward. This has been going on for days now.
Received 8,928 Likes
As for the OP it might be a good idea to jack the wheels up and with your hands in the 12 and 6 position on the wheel try to rock it up and down. If you get more than a small amount of movement you may need to replace the bearing. Also make sure the brake pads are pushed away from the rotors and check for any rough feeling in the hub when you turn the wheel by hand.
C1221 through C1224
All of the following conditions exists for 2.5 seconds:
• The suspect wheel speed equals zero.
• The other wheel speeds are greater than 8 km/h (5 mph).
• The other wheel speeds are within 11 km/h (7 mph) of each other.
Also use a DVM to check the output resistance and voltage of the wheel bearing. Disconnect the connector where the lead from the wheel bearing connects to the car. Resistance should be 850-1350 ohms and the Voltage level should be greater than 100mv when you spin the wheel.
If that check shows things are fine then the problem is in the harness going to the EBCM or in the EBCM.
Bill
Bill has you covered. You either finished off a failing wheel hub or you somehow damaged the wiring for that wheel.
You won't bugger the wheel speed sensor by jacking the car like that unless the bearings are already going bad.
What's C1233 mean? It's easier to tell us when you already know instead of making us search.
Peter
Peter
Had a free moment to jack passenger side up and try to move the wheel up and down, back and forth and side to side. She did not move. No noise while spinning the wheel.
Swapped out wheel bearing and same issue. The shop where I went says he has seen new wheel bearings come bad and he would like to try one more set b4 we go any further.
[QUOTE=lucky131969;1579529285]Was any of the advice given in post #4 followed? Any troubleshooting?[/QUOTE]
Check post #7. I had the mechanic do the same. The only thing I did not do was check ohms and voltage.
And that would be the most important part.
Whoops, a little late!
Guys give me a break. I have a 3.5 year old that has my attention when I am not working. I could not find my dvm last week. We will check tomorrow.
No one is going to knock you for being a good father You create confusion when you ask for help, are provided specific things to check, and do not follow through. Simple as that. So do the checks, and report back when you know more.
how did you perform the test? i.e. where did you connect the meter leads, and what setting did you use on the meter AC or DC? Also, did you spin the wheel?
