Need a GOOD alternative to Headlight insulators/tab stops/bumpers
http://forums.corvetteforum.com/c5-p...e-47-99-a.html
Used that kit.
So, the same thing happened last night - I flipped the headlight switch and nothing happened. Flipped it a few times and the Driver's Side came up (keep in mind that it used to be the other way around before the new HLCM). Finally after a few more flips both lights popped up.
What's going on here guys??
Would I be correct in assuming you have gone back and rechecked all the plugs and connection... As in taking them apart and reseating them?
My car has a couple of wires where the PO tried to open a plug by pulling on the wires with a set of pliers.
Anyway, when the lights haven't come up have you tried wiggling connectors / wires instead of repeatedly flipping the light switch? Just an idea...
My feeling on the solid gears is that they jamb pretty hard when they hit the stop since there is no rubber to act as a buffer. I have no idea what to recommend to try and fix it.
My bumpers do look about like yours but they've been on the car much longer. A certain amount of indentation would be normal.
I guess you could look at the old module and see if there is a low ohm resistor used to sense the current. It might be possible to increase the resistance slightly and lower the force.
Good point about the solid gears Peter, but the thing that makes me doubt them as the culprit is the fact that my problem has been almost completely isolated to one headlight (first the DS, now the PS) and not both. Both headlights have the solid gear.
What are the chances that my headlight switch is bad?
The lights are definitely working better with the new HLCM installed, but the random misfires still have me wondering what the real deal is...
Anybody?
Good idea, I'm going to check the connections tomorrow. The reason I haven't in the past is because I am (or was) 95% sure that the reason the headlights were getting stuck in the down position is because the manual ***** were being overtightened by the headlight motor/hlcm. So it was more a of a mechanical issue than a problem with the wiring. I'm starting to consider every possibility now though because we're running out of options.
Anybody?
Anybody?
You can order from Ecklers
http://www.ecklerscorvette.com/corve...1997-2004.html
Corvette Headlight Stop Bumper, 1997-2004
- Reproduction Of Original
#33
This has already been tried. Eckler's reproduction stops are brittle and it actually split in half after a week of taking the force of the headlight coming down. What type of hard plastic hosing did you use? I haven't found anything (hosing or otherwise) that has held up.
#34
That's the thing - the problem arose BEFORE the new gear in the DS headlight was installed. The driver's side would get stuck just about every time and I'd have to get out of the car and loosen the manual ****. This was with the factory gear still in place. It eventually stripped and I replaced it with the solid gear to match the passenger side. So the problem has occurred with both types of gears in place. You think they are jamming though?
I was just thinking that the motor itself may be putting out too much power (with any gears) or it is not responding to the "stop" signal quickly enough. I am not sure if the headlight motors work like the window motors? But the window motors shift the motor armature to shut off. If they are similar in design maybe it is just taking too much power to get the armature to shift?
#35
Got a link to some pics of these window motors with these shifting armatures? I'd like to see how it could shift back if the shifting is what turns the power off. And also how it's held from bouncing back on a bump in the road and moving the window by itself. I always understood the motors were controlled by relays in the door control modules that sometimes fail and need to be replaced but I've never really looked at the window motors very closely.
Peter
#36
The problem with the DS headlight not popping up didn't go away after I installed the new gear and got rid of the plastic one, however.
#37
Did you send them back or tell them? What I did was take a piece of fuel hose and cut it. Then I took a small hose clamp the ones you put say on a fuel line and I cut it. I put that into the fuel hose and inserted that as a stop tab. It hits the rubber part but it's not to soft because the metal piece of the hose clamp is the middle. It doesn't look pretty but it does the job and has been going strong for over a year.
#38
Did you possibly damage the motor in some way or assemble it improperly? Is the motor loose on the housing? Was the worm gear damaged?
Try taking the arm off the motor, rotating the motor 1/2 turn and putting the arm back on.
The rotate trick made my motor work for the rest of the summer. My motors have screws so I just bought a $10 Dorman plastic gear and stuck it in. For some reason, it's a little noisier now but the headlight goes up and down fine.
Peter
#39
The gear replacement was not meant to fix the headlight getting stuck. I replaced the gear because the plastic one had stripped and was making that awful sound that we all know very well.
That's a pretty good idea putting the metal piece inside the rubber fuel hose! I may have to try that down the road. Thanks.
Well, the plastic gear wearing is a very common cause of the headlight sticking.
Peter
Peter
#40
Alright fellas, I'm fed up. Turned my lights on to leave work and everything worked fine. Got to the gym and after working out I went to flip the headlights up - nothing (on either side). Had to get out and turn both manual ***** a half turn. And of course, everything opened just fine. I'm at the point of wanting to sell this car due to this headlight issue (no I don't want the fixed headlight option). Here are my only 2 ideas left:
1. Try different gears, other than the hardened aluminum
2. Replace both headlight actuator motors. This would cost me about $460 but if it's a sure fix I'll gladly pay it at this point.
Heavily leaning toward #2, what are anyone's thoughts?
