cut a hole to bleed the clutch
Has anyone with a C5 done this? I'm having trouble finding more info.
http://ls1tech.com/forums/manual-tra...-yourself.html
I've been having battling the "pedal stuck to floor" issues for a while now and i'm tired of pulling the exhaust/cover etc off to bleed the clutch. I purchased a remote bleeder but found out (the hard way) that it can't be installed without the whole shebang removed so it's useless to me unless I get to the point where i'm changing the clutch.
St. Jude Donor '09-'10-'11
Just do this: LINK
Thanks for the response. Unless i'm reading wrong your method is just to remove air. I would like to be able to flush the entire system frequently. So I am still interested in cutting this hole if it's not too bad on a C5.
halltim
I understand your dilemma as I was in the same position before I installed a remote bleeder line and clutch when my transmission took a poop.
Unfortunately, as far as I know the only option other than cutting a hole is to continually do the Ranger method of draining and refilling the reservoir. Or, bite the bullet and do a clutch or transmission job at which time you can install a remote bleeder line.
Cutting a hole might be a reasonable alternative. I know I cut two holes in the back deck of my car so I can easily reach the adjusters on my after market rear shocks. Just keep in mind that cutting a hole is not easily repaired if you decide you don't want it anymore. Even if you do cut a hole you need a blocking plate/plug. The hard part might be figuring out where to cut the hole. If you're lucky someone here has done it and can give you measurements on where to cut. If you do cut a hole start with a small hole to check for placement, then enlarge the hole in the direction you need for maximum function.
Good luck.
Dog
Good luck.
Dog
halltim
Good luck.
Dog
Good luck.
Dog
Deviant LS6, Evidently you dont have long tube headers , in order to accomplish this?
Your profile didn't state whether you had them or not.
I would recommend doing it right and installing a remote bleeder system. It seems you're getting some smart a$$ answers on the question, but I think the right one is to spend the time and $100 to know the job is done properly.
I understand the frustration that goes with trying to bleed the clutch assemble using the factory system, but do it once and get it over with.
The common consensus is that the TPE bleeder is the one to go with.
I think it'd be easier to find someone doing a clutch replacement and have them measure out where the bleeder is while it's easily accessible. Or, perhaps you could head to a local Vette shop and see if they could measure on a car they're working on (probably some $ for their time). Either way, I'd want to know for sure where the bleeder is before I cut a hole in my car, but it doesn't seem like a bad idea so long as said location is easily hidden and you properly block the hole from water & noise infiltration.
Was under the car last night and glanced up in this area while I have my headers, tourque tube, etc. etc. out.
Another important thing to remember on the Vette, the fuel lines run right by where you would need to drill
I think i'll focus on finding a way to install my remote bleeder without removing the torque tube... if the bleeder was longer it wouldn't be a problem so i'm on the hunt for a extension of some sorts.
You could easily pop a tube over the nozzle and point the output into a bottle or down below. There is not very much fluid in the entire system (that's one of the problems).
You would go down in history if you figure this out. Plus there is a huge aftermarket for trap doors to cover the hole.
Some are born great. Some have greatness thrust upon them.
I've decided against this. The main reason i was thinking of doing this was to easily flush the entire system often, but i didn't think about how much fluid will be dumped on the exhaust etc.
There are pictured write up's of this proceedure being done.
Good luck.
