C5 Torque tube tear down and re-build with pics
Old 08-30-2016, 12:08 PM
  #101
915ls1
2nd Gear
915ls1's Avatar
Originally Posted by regorih
One the bolts are out tap the front shaft with rubber malet to separate the drive shaft from the tube. Slide tube free and pull drive shaft out
Would you have a extra driveshaft you would want to sell?
Old 09-06-2016, 10:09 AM
  #102
regorih
regorih's Avatar
Sorry I don't. I think you'll have a hard time buying just a stock driveshaft. Best be would be to buy a used torque tube.
Roger
Old 05-15-2017, 05:25 PM
  #103
ArtGle
Support Corvetteforum!
ArtGle's Avatar
Glad you brought this thread back to life.
I see the last post was 2016. oops
My own 99 Coupe A/T not having a problem at 155K+ miles.
My buddy, sitting here with me at the moment has a 99 Nassau Blue Coupe, 'except' his car is 6 speed standard trans.
My question, I'm asking for him, (and myself at this point)..
How do 'we' determine the size of the couplers in our cars?
Or is this just something we have to "wait 'till we tear it down to find out"?
Thanks in advance.
Art
Old 05-16-2017, 01:41 PM
  #104
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Art
I "THINK" that all 97-2000 cars have the smaller couplers. My buddys 2000 A4 Had the smaller couplers. We changed them with Dorman REPlACEMENT junk and they failed shortly after and we had to install the GM Couplers.
Bill
ArtGle (05-20-2017)
Old 05-20-2017, 01:25 PM
  #105
ArtGle
ArtGle's Avatar
OMG... Chevy dealer quoted 'discounted price' for couplers.
$200.oo EACH
Old 05-20-2017, 06:53 PM
  #106
Rx7Rob
Rx7Rob's Avatar
I got them for $132 / ea at GMPartsDirect.
ArtGle (05-22-2017)
Old 05-20-2017, 06:56 PM
  #107
pewter99
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
if you want a torque tube that has been fixed I will be selling one with less than 200 miles on it just rebuilt with all new couplers and bearings
Old 05-21-2017, 02:31 AM
  #108
My Vette Life
My Vette Life's Avatar
how much and shipped to 93065?
Old 05-23-2017, 02:29 PM
  #109
ArtGle
ArtGle's Avatar
Couplers enroute from Patrick. YAY
Old 06-16-2017, 09:00 PM
  #110
andy_t
andy_t's Avatar
Default TT related ?
Hey CF - Going to Bump this to keep all this C5 Torque tube related material in one place, hope you don't mind. Its the #1 google hit for all things C5 TT.
I am rebuilding my 2004 C5Z TT right now while I have the driveline out to replace the clutch.
I installed the shaft back into the TT housing with new bearings, snap ring went in like a charm, but the rear bearing housing is spinning inside the TT. From what I remember it was nice and snug in there before I removed it. Ive searched and consulted my service manual, although its not much help as its from my old 99 coupe and thus shows the old bolt-style TT. I even tried tapping the input shaft with a hammer/block (as if to remove it) thinking maybe it needed to seat against the snap ring, no dice.
Just turning the input shaft by hand the housing will stay put, but I can easily grab the housing at the back end of the TT and rotate it. Thanks for the help all!
Old 06-22-2017, 07:26 PM
  #111
Kswann2009
Kswann2009's Avatar
Default tool and torque
Hello. I have the service manual but alas, it is 2 hours away from me, I bought some bolts from a local fastenal, 12.9 grade, and a t50 fits it, as it does the factory bolts. My question is, what is the torque specs on a torque tube for a manual. I read 68 ft/lb is pretty standard for manual and 55 ft/lb for automatic, just looking for clarification. With this clarification, what kind of tool should I use to torque them with? a Torx 50 1/2 drive bit?
Old 11-10-2021, 12:49 PM
  #112
Drift Vette
Drift Vette's Avatar
Keeping this thread alive.
The torque tube coupling bolts are discontinued.
Any luck with aftermarket bolts?
Old 11-10-2021, 01:32 PM
  #113
RonSSNova
RonSSNova's Avatar
It’s not a TTY bolt. So I’d think you can just re-use them unless they are damaged.
Quick Reply: C5 Torque tube tear down and re-build with pics
