C5 Emergency Brake Adjustments
`The stock brake is weak,especially if adjusted to spec using the factory tool. Adjust so that you have to put some effort into getting the rotor/drum back on. The brake will be as strong as it can be,and drag won't be an issue. This has worked great on my car for years.
Anyone else ever had their parking brake "auto adjust" after they've shut the door? Mine adjusts (little bit of a "pop" after you pull up on the handle the third time) as it it should, but every now and then (usually after a couple stops when running errands) I'll set the brake, get out, close the door and be greeted with a "pop". If I get back in and reset the brake it feels like it auto adjusted. Thankfully the first time this happened was in my driveway (car was running and in neutral) and the car only rolled a foot or two. Since then I've never trusted it...
Not trying to hijack... sort of the same subject...
I agree... but I never could find anything wrong. The cables are all normal, the ratchet mechanism looks fine (nothing loose and no abnormal wear). The brake holds great at about 1/2 way up. Eh... what are you gonna' do (other than leaving it in gear when I park)...
None that I know of. Keep in mind, for a LONG time, GM had the column lock set up so that you had to shift the car into reverse, in order to be able to remove the key....
This
They all came adjusted like crap from the factory. When I put the rear rotors back on, I adjust out the parking brake until it just starts to give some interference.
When I replaced my rear rotors I didn't have the parking shoes tight enough and had to pull it back apart. I adjusted them until I could barely get the rotors on by hand. It will now hold the car on an incline.
#33
Hey I'm new to this whole DIY thing but I need to do this e-brake adjustment, it takes me at least 3 times to get the e-brake to "catch" when I park. I have never messed with brakes but this is going to be my project this week.
With that said, how do you know how far to adjust the star wheel? I read you guys saying until its hard to put the rotor back on but am still a little confused. A little more explanation would be great. Thanks!
#34
star wheel
#35
Mine was horrible and I have been lightly pulling mine 2-3 times every time and it holds fine now. I am too lazy right now to pull the rear rotors so it is working for me. You also might try backing up and pulling on it slightly several times. That has adjusted it on other cars in the past.
#36
i just did this adjustment, pretty straight forward. The biggest surprise was the inner inside ring of my rotors where the drum presses against the rotor was two different sized 7.4375" and 7.5" so I had to set both star wheels at completely different settings. The only downside I see is one side might work harder than the other but it is what it is.
#37
#38
no way no how will pulling up on the handle a few times OR backing up will not adjust the parking brake. not happening. sorry guys. i was looking around to see if anybody made upgraded shoes and found this thread. the mechanics of this system has no self adjusting features at all.
#39
#40
Pumping won't adjust the brakes, but it will take slack out of the cable making them hold tighter.
