ABS/Traction Control Light is on
Mar 20, 2012 | 09:04 PM
have a 98 c5, and both lights came on at the same time..? can anybody help..?
Mar 20, 2012 | 09:57 PM
that means your EBCM = electronic brake control module has gone bad. Just like mine.
Mar 20, 2012 | 10:07 PM
damit....!!!!!
Mar 20, 2012 | 10:08 PM
Quote:
Originally Posted by
Sinister-one
Not necessarily.... both of those come on when the steering position sensor goes out also. We need to know what the codes are from the DIC.
Mar 21, 2012 | 11:06 AM
Wounded Warrior Escort '11
Sinister-one
Okay, not to highjack your thread, but here's my codes:
28-TCS
DTC C1233 RF Wheel Speed Circuit Open or Shorted
DTC C1243 BPMV Pump Motor Stalled
DTC C1277 Requested Torque Signal Circuit Malfunction
AO-LDCM
DTC B2282 Battery #1 Circuit
DTC B2284 Battery #2 Circuit
A1-RDCM
DTC B2283 Battery #1 Circuit
DTC B2285 Battery #2 Circuit
You already posted your issue in a new thread, so please remove this post, from the OP's thread therefore not complicating things. No offense meant
Mar 21, 2012 | 11:52 AM
dgrant3830
DONE !!
AND No offense meant.
Mar 21, 2012 | 11:57 AM
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
When I'm racing my '97 I'll occasionally throw the same warnings. I clear the codes and they usually don't come back for months.
Mar 21, 2012 | 12:35 PM
doje
yeah, I cleared mine last night and they came back this morning when I drove out of the driveway....
Mar 21, 2012 | 04:08 PM
I have been down this road with my 98 and I finally fixed it with a tool I built to exercise the motor in the ECBM. With the early models you can get to the module and run the motor but you have to also open the solenoids to allow the motor to pump the brake fluid. Check some of my posts and you cna see what I mean. I was able to pump fresh fluid through the motor and I have had no more problems.
