C5 power steering leak. Please help
I noticed I have a significant power steering fluid leak (drivers side)
Does anyone know of a product or rebuild kit to fix the leak? Had a friend who is a mechanic look at it and he says its fixable if I can find a new gasket or rebuild kit. Has a anyone else had this problem and how was it fixed?
Any help would be greatly appreciated. Thanks guys.
Thanks for the reply. He did mention something ballooning up and said it could burst if we don't fix it soon. Iv heard rebuilding or solving a major issue with the power steering can be costly and/or difficult to find a fix for. Thanks for the help.
Sorry about that, the appeared to be where the shaft meets the actual power steering gear on the drivers side. My mechanic said the seal is bad.
Yesterday my '98 sprung a leak in the high pressure line connecting the pump to the rack. Even up on the lift, it is unclear to me what the procedure is to replace this line. This is my first Vette, and I've only owned the car for two days- I haven't had a chance to pick up a service manual yet. Can someone give me a basic rundown? What all has to come out? Thanks in advance...
Doug
wow what a freaking coinsidence. im about to replace my pressure hose in a couple days and wondering the same thing. Im not sure if its coming from my hose or not but for 15$ it prob wouldnt hurt to swap it out for a new one. BUMP FOR INFO
OK, I got lucky - I was able to loosen both fittings from the top of the car without removing anything. All I did was drain the reservoir first. Jacked the car up to reinstall new hose from the bottom, then tightened from the top. Not a bad job at all.
Still not sure what I would have faced had the fittings not come loose. It would have been much worse, that's for sure...
If yours is leaking double-check the lever and DO NOT overfill.
