Steering wheel lock HELP
Old Apr 23, 2012 | 06:39 PM
dbvettez06's Avatar
dbvettez06
Default Steering wheel lock HELP
YES i read the notes on this wonderful feature...But please read...My battery died, i jumped it and drove it, it ran fine..Several days later went to start, it was dead...Replaced the battery today . And behold i get this steering wheel lock....I know it happened because of the battery, any other ideas or anything i can do??
Old Apr 23, 2012 | 08:17 PM
Jumper11's Avatar
Jumper11
Happened to me. Pull the key out for about 5 min. Then agressively shake the steering wheel back and forth against the stops. Then put the key back in and try to start it. It started working for me. I replaced the battery and all is well. I plan on deinstall the GM recall and install the CLB. Good luck.
Old Apr 23, 2012 | 10:20 PM
87SAM's Avatar
87SAM
Non GM CLB.
Old Apr 23, 2012 | 11:08 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
First try to read and CLEAR ALL the DTCs! Once you have cleared them install the key and see if it unlocks.
Try to insert the key and turn the ignition to ON and off several times while shaking the wheel back and forth fairly hard.
READING YOUR Engine Diagnostic Codes (DTCs)
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open etc…)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes)
If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, C or ;H. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present;
press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET
To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
Here is very good site of DTC definitions:
http://www.gearchatter.com
Make sure to include the H or C suffix!!
Old Apr 24, 2012 | 08:03 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
There is a relay which will burn if the battery goes low. 8VETTE7 is the person who knows this system real well and you've already got BC on the case!
To Steering wheel lock HELP
