will not start
Old Apr 23, 2012 | 07:39 PM
hermancar's Avatar
hermancar
Default will not start
My 1999 c5 will not start, My codes are. 99-hvac-no comm,60-ipc-u1160(hc),u1176(hc), 58-sdm-u1000(hc),u1064(hc), 40-bcm-no comm,28-tcs-c1286(hc), 10-pcm-p1626(hc_. These are the codes with history and current. There are more with history only.
My car will not try to start,windows will not work,dash will not lite up, says low fuel with half tank of gas and reduced power just to name a few items. When i first noticed my battery only had 11.5 volts. i charged the battey but that didnt help. any advice would be greatly appreciated. Thanks
Old Apr 23, 2012 | 07:44 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
so when you turn the key does it do anything.. can you hear the fuel pump kick on?
how old is the battery?
is it leaking down into the BCM?
Schubs's Avatar
Schubs
Try taking the battery cables off the battery and touch them together for 30 seconds, this resets the computers, a lot of times when the battery goes low, the car just freaks out and has to reboot.
Old Apr 23, 2012 | 08:13 PM
hermancar's Avatar
hermancar
Default wont start
At the 11.5 volts pump did nothing, but after charging the pump started and guage hands swep right to leftwhen i turned the key on. I will try the battery cable removel the touch them together.
Old Apr 24, 2012 | 08:10 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
With the battery that low, it won't work at all. New battery and still didn't go is unusual. With the new battery in it and note that it must be at or above 12.5vdc for the computers to run, clear the codes and pull them again.
To will not start
