C6 Instrument Cluster in a C5. And it works.
I came across a cheap C6 cluster and decided to play around a little bit. I bought the connectors at mouser for about 5 bucks and tried some simple test fits. It seems to work well. I did get an error saying to "Service Fuel System". I don't know if the fuel gauge works seeing as I was low on gas to begin with. All of the other gauges work as they should. I will say that the LED backlighting is a nice touch even in the daylight. I didn't play with hooking the HUD up and the DIC buttons will have to wait when I get bored again as I don't have that harness from the cluster to the switches. I am sure that the ability to read codes is gone and I can say that the traction control switch being depressed does not do anything on the dash. The blinkers still worked, but did not appear on the dash.
Like I said, if I come across some of that other stuff cheap, I'll play more. I want to try a BCM from a C6 to see what I can get to work, so if anyone knows where I could pick one up cheap, let me know!
http://s1098.photobucket.com/albums/...=VIDEO0015.mp4
Cruise-In VII Veteran
Nice work, keep us posted on the gas gauge, looks like that is the major player here in making this work
NOTE: the late '03 cars used the same setup as the C6(fuel pump and sender is top of the tank........although besides the air bag(needs to be moved), I've never seen any issue regarding the fuel gauge between the C5 cluster years(when used in 97/8 to get the HUD connector)
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
really cool!...great stuff, venturing into new territory on the C5. I thought I had seen it all in the 14 years here....keep us posted
Received 1,675 Likes
Really looks pretty good.
What am I missing? I just clicked that link and saw a set of gauges that are just like the C5 cluster. Other than the DIC display which said "Corvette by Cheverolet" Is that it?
I guess it's a way to replace your C5 cluster if they are no longer available? Great job...
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WOW!! WELL DONE!! Thats talent!!
Plus it was something to do. It hasn't been done from what I've seen so why not try something new? I'm sure I could get a HUD to work to. GM has always been good about sticking with what they know and what works. A lot of their stuff that is interchangeable would really surprise some people.
