Zo6 Side Scoops-Installation
Thanks in advance for your response.
Marc-Bend, Oregon
It's real easy to make your oun template with a thin piece of flexable cardboard. Just form it to the inside of the plastic scoop, trace the outer edge, cut along the traced line. then cut a hole in the cardboard to match the inner opening, and mark the bolt holes. Now place the template on the rocker pannel where you will palce the scoops and mark the inner opening hole along with the position of the bolt holes on the paint. Flip over the trmplate for use on the other side.
Cut the holes once you are SURE you have all markings in the correct place. Remove the inner linner of the rear wheels and install the bugger. Good luck with your project. :D
If the only reason you're installing Z06 style scoops is because they make your car look more like a Z06, there's a word for that: rice.
Looking good BParker! :cheers:
Good to see you are still around! :D :seeya
Have you ever heard about cooling air to the rear brakes? No, I guess not, otherwise you wouldn't be making conclsuive statements like the one above. Believe it or not, some people add the Z06 scoops for practical purposes and not to just impress others. And if you think that the ACI scoops look better than the Z06 Scoops, Great. Everyone is entitled to their opinion.
:D :D
That is AMAZING Rand, you can read his mind and intensions :crazy: :crazy: :crazy:
:D :D
If it is brake cooling you want, I think the ACI vents make a much more attractive option. ACI's website is http://www.acivette.com. Here's the specific page with the vents: http://www.acivette.com/aci0026m.htm. The ACI vents are cut into the panel, as opposed to having plastic that sticks out of it to collect the air. As I already said, I believe that the Z06 brake vents are very cheap looking. I really think that they detract from the car by making it look as though they didn't put much thought into it.
Now, the ACI panels aren't cheap. I believe it was about $600. And, as you have said, everyone is entitled to their opinion. Mine is that the ACI vents are much nicer than the Z06 style vents. If you believe that the Z06 style vents look better, or are simply more practical, than that's great. However, if you put Z06 style vents on your 'Vette to make it look like a Z06 to impress others, then that is rice.
