tx emission...
Old Jun 8, 2002 | 01:01 AM
00c5coupe's Avatar
00c5coupe
Default tx emission...
will h/c and custom program pass tx emission???
Old Jun 8, 2002 | 01:25 AM
SR1654's Avatar
SR1654
Default Re: tx emission... (00c5coupe)
ooc5coupe..I just did my inspection under the new inspection rules and passed with flying colors! :cheers: I have an MTI T1 cam and stock heads with some other extras (see my sig). I would think that you would be just fine with new heads also. Good luck! :)
Old Jun 8, 2002 | 01:37 AM
00c5coupe's Avatar
00c5coupe
Default Re: tx emission... (SR1654)
did you do a custom program?
Old Jun 8, 2002 | 01:39 AM
SR1654's Avatar
SR1654
Yup..Had the LS1 Edit dyno tuning done after my cam install. No problems at all.
Old Jun 8, 2002 | 05:13 PM
zoomnz's Avatar
zoomnz
SR1654...Where are you getting your work done at?? Or are you doing it yourself???
ZOOMNZ
Old Jun 9, 2002 | 08:34 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Its my understanding all they do for 96 and newer is plug in a diag tool to the OBD-II port and check for any codes or malfunctions. There is no dyno run or tailpipe readings done. Is this correct? If so, with proper tuning/code deletion, you could get pretty wild with heads and cam, and pass since no dyno/tailpipe sniffing is done.
Let us know.
thanks
To tx emission...
