What Manual Trans Fluid to use in six speed?
Old 06-11-2002, 12:45 PM
Mike TexaSS
Mike TexaSS's Avatar
Default What Manual Trans Fluid to use in six speed?
I saw a relpy noting on how smooth the car shifted after changing the manual transmission fluid. So what fully synthetic oil can i use and what fluid can i get from a jiffy lube or o rileys or autozone??
Old 06-11-2002, 12:51 PM
wwashing
wwashing's Avatar
Default Re: What Manual Trans Fluid to use in six speed? (Impala SS Z06)
You want to use ATF (Automatic Transmision Fluid), not MTF. Check you owners manual for the specifications, you can use any Synthetic that meets that standard. I've been using Redline D4 ATF for 3 years. Mobile One also makes one that meets the specs.
Old 06-11-2002, 12:54 PM
Mike TexaSS
Default Re: What Manual Trans Fluid to use in six speed? (wwashing)
But redline makes a MTF fluid i saw it at my buddies shop yesterday so why would you use a automatic fluid in a manual? Just wondering no flames here!
Old 06-11-2002, 01:09 PM
mbtc5vette
mbtc5vette's Avatar
Because the owner's manual says so. Newer MT's are using ATF instead of gear oil - probably for mileage reasons but there may be others. Putting gear oil in would surely invalidate your warranty. Don't know if it would really break anything. Anyway, use synthetic ATF. Mobil1 ATF works for me.
:cheers:
Old 06-11-2002, 02:30 PM
IMQUIK
IMQUIK's Avatar
AMSOIL ATF!! :yesnod:
Old 06-11-2002, 03:04 PM
SoCal C5
SoCal C5's Avatar
...so why would you use a automatic fluid in a manual? Just wondering no flames here!
The syncros in an MN6 are different than the transmisions of yesterday. Your MN6 has cone shaped syncros with a friction material much like what is used on the clutches of an automatic. Older transmisions had splines that meshed together.
The friction material on the syncros and no doubt Mileage/efficency are the main reasons for the use of ATF.
Old 06-11-2002, 03:06 PM
RWBJR
RWBJR's Avatar
I would use Amsoil's ATF product. I use Amsoil fluids in all my vehicles; oil, transmission, and gear lube. Check out the preferred membership. For $10 you get a six month membership and you'll receive approx 15% discount on these products.
Old 06-11-2002, 04:06 PM
kewlbrz
kewlbrz's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Redline D4-ATF :yesnod:
Old 08-08-2017, 06:46 PM
Jumper11
Jumper11's Avatar
Default C6 Manual Transmission Fluid
I have 45K on my 2006 Manual Transmission and wanted to change out the fluid. What does the forum recommend? Thanks
Old 08-08-2017, 09:16 PM
Georgies
Georgies's Avatar
I used royal p. No probs here...
Old 08-10-2017, 06:05 PM
JBB
JBB's Avatar
Mine called for: MM6 (6-SPD) GLS All TEMPS TA1
TA1: GM recommends P/N 88861800 (Canada 88861801) or equivalent for manual transmission, transfer case applications.
That crosses to Dextron III (Non-synthetic)
<cut & past from GM TSB>
If fluid part number 88861800 U.S. (88861801 Canada) is unavailable when servicing a manual
transmission or transfer case, Dexron III can be used in it's place. DO NOT use Dexron VI in place of
the manual transmission fluid in any manual transmissions or transfer cases as a failure may result.
Old 08-10-2017, 06:13 PM
Spaceme1117
Spaceme1117's Avatar
Received 1,314 Likes on 886 Posts
I have been running Royal Purple SYNCHROMAX and have no complaints.
I have always heard Redline ATF is great also.
Old 08-11-2017, 12:39 AM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can NOT beat AMSOIL Torque Drive ATF. Best stuff I have used so far!
I KNOW it works! IT WORKS VERY WELL! Its compatable with early and late C5 MN6 Transmissions and C6!!
Bill
The following 2 users liked this post by Bill Curlee:
Jumper11 (08-14-2017), redzg (08-15-2017)
Old 08-14-2017, 06:57 PM
Jumper11
Jumper11's Avatar
I went to advance auto and tried to find Dextron III with H requirement. No longer available. It's replaced by Dextron VI synthetic. States right on the label "replaces dextron III with H requirement. I changed it and seems to be smoother. Let me know if this is not recommended. I know the C5 manual in some years had paper bushing and synthetic was not recommended. Thanks in advance.
Old 08-14-2017, 09:12 PM
Paul 75 L82
Paul 75 L82's Avatar
Royal Purple Synchromax
Old 08-15-2017, 10:38 AM
jjc508520
jjc508520's Avatar
Bill
I met an Amsoil distributor at Carlisle last year and to my surprise he responded to my emails about the C5 MN6 trans fluid. An excerpt from his email appears below:
For all GM Transmission specs - Dexron VI states all previous GM specs are obsolete. Meaning if your owner's manual calls for a Dexron III or IV, you use Dexron VI.
AMSOIL's ATL is the recommendation for these specifications. (ATF Signature Series Fuel-Efficient)
The Torque Drive Transmission Fluid was formulated Allison products, and covers the TES289 and TES389 specifications.
The rep has said he will be at Carlisle again this year and will have ATF on-hand - I'll be bringing some home with me...
Jerry Mikielski, Jr.
GK Synthetics, LLC
Independent AMSOIL Dealer
DEF Distributor
(570) 239-5330
Http://amsoil.gksyn.com
Old 08-15-2017, 11:19 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
An EMPTY new MN6/MN12 manual trans takes 4 qts of ATF. If you drain and fill yours, you will use 3.75/ish qts!
I also use the AMSOIL Products and am very happy. AMSOIL just changed some of their product lines and now recommend that signature series ATF. TRUST ME,,, The Troque Drive ATF worked and worked very well! Even in the Early MN6 trans!
Recommend you change out the diff 75/90 at the same time. Get the GL-5 stuff that has the limited slip additive in it.
Bill
redzg (08-15-2017)
To What Manual Trans Fluid to use in six speed?
Old 08-20-2017, 10:47 PM
CaliforniaJack
CaliforniaJack's Avatar
Default How much?
How much GL-5 Diff fluid do I need for a change?
Old 08-21-2017, 04:10 PM
feeder82
feeder82's Avatar
2 qts
Old 08-23-2017, 07:46 PM
The Wrench
The Wrench's Avatar
Just recently drained the Amsoil torque-drive and filled with the new signature ATF. The new fill actually seems a bit better; although the torque-drive was very good.
DG
Quick Reply: What Manual Trans Fluid to use in six speed?
