oil life display
To get the change oil light to go OFF and to re set the life meter:
1. Turn ignition key "ON" without starting the engine
2. depress on the gas pedal FULLY--(wide open -floored) and lift off the pedal COMPLETELY ------ 3 times in a row
3. Turn key off
the meter is now re-set to 100%
the algorithms that determine the decrease in oil life integrity subtract from that bench mark. typical oil life is between 3,000 miles to 6,000 miles... based on how you drive.... this system is much better than changing your oil every 3000 miles and better for the planet and your pocket book , if you follow it. Also you never want to exceed 0ne year of service because carbon and metal breakdown causes an acid PH of the oil, this causes thermal breakdown of the oil and the additive package it can also effect gaskets and seals ... one year is where you want to change your oil if you don't hit the 0% mark.
here is a quick logic analogy:
Car #1 is a daily driver.. car sees highway driving @ 50 mph.. engine sees avg. 1200 rpm in 6th gear. so in an hour of driving @ 50 mph, the engine sees 72,000 revolutions of work. ( 1200rpm X 60 minutes = 72,000 revolutions of work.
Car#2 is Not a DD. car sees city and local traffic, never sees 5th or 6th gear, never sees an over drive gear. Combined city and local driving sees an "average" of 3,000 rpm, running through the gears at each stop light and stop sign, and rarely seeing 4th gear.. So Car #2 sees the same 50 miles although it may take several days but Car #2 sees 180,000 ( 3000 rpm X 60 minutes= 180,000 ) revolutions of work to cover the same 50 miles.
So car #2 sees 2 1/2 times the work that Car #1 sees in the same 50 miles. This is just using mileage .. consider that Car# 2 also sees many cold starts, closed loop, lugging under load, etc conditions to go the same 50 miles, that my take more than several days, further degrading the oil that Car #1 never sees in his 50 mile journey of a single day
Doesn't this seem logical?
This is why the OLM is much better than a single Number using mileage as the oil change criteria.
People will argue that if they change their oil every 2000 miles, they are protecting their engine better than what the OLM does... this may be true but you are wasting resources and throwing money away.. especially if you do 10,000 miles a year... that's 5 oil changes a year, where two changes may be enough for the same 10,000 miles, and for those who pay someone to change the oil, thats 375 dollars a year vs. 150 dollars a year for the same protection. Throwing away good oil is what many people do.
Bill aka ET
Bill aka ET
( 6000/10000 ) * 15000 = 9000
or rather ... drive to 0%, reset, drive to 50%, change oil?
For those who take their car to a shop.... at 10 % is when you should be making an appointment, especially if the shop is busy and it takes a few days to get you in. If you go over a day or two ( I don't recommend you get into this cycle ) its OK but not recommended...of course we all know about the one year ( no matter what the oil life says... the OLM does not measure or test the actual oil, only the way you drive...
, I have gone to 15%, but no less!
