Best Tire Pressure On Your C5 With Non-Runflats?
What gives you the best performance in comromise with the best tread life??
I just had a set of GY Eagle F1s (non-ruflat version of the EMTs) put on today and they came out of the shop with 35 psi in all 4 corners...I set them all at 32 psi and was wanting your opinions based on what you are getting the best all around of both from??
As always, TIA :cheers:
Re: Best Tire Pressure On Your C5 With Non-Runflats? (Mad_Dog)
Thanks guys for the responses.. :cheers:
I'll set them down to 30psi on all 4 corners and see how she handles..
Not too much sidewall roll at that pressure in high speed corners, right???
thanks again :D
thanks again :D
Re: Best Tire Pressure On Your C5 With Non-Runflats? (gmblack3)
:cool: Thanks, they'll be at 30 psi all around when she slides out of the garage next!! :cheers: :seeya :flag
Re: Best Tire Pressure On Your C5 With Non-Runflats? (BAD2BNE)
The tire pressure will increase about 2 psi after the car is driven.
I run 29 psi (cold) on the original tires.
I have brand new non run flats that I just put 2,500 miles on last month at 29psi. There is a noticable ridge across the center of all 4 tires that indicates the pressure is too low. I just changed them to 33psi to try and even out the wear pattern. I also get a little roar so maybe this will help that too.
Nitto 555R currently on my car. Chase the TP depending on outside temp will drive you crazy. I try to run near 30 at all corners every season of the year.
Received 8,915 Likes
It doesn't depend on the type of tire. The manufacturer sets the recommended cold pressure based on the weight and performance characteristics of the vehicle. Go with the factory recommendation. In the old days the factories recommended softer pressures to make the cars ride easier but that went out many years ago when gas mileage became a paramount concern.
Bill
Bill
bobby777 is exactly right except he leaves out one vital piece of data - the definition of "cold". Cold is defined as 53.79 degrees Fahrenheit at an altitude of 2356 ft.
Received 1,227 Likes
St. Jude Donor '11
As always, TIA
As always, TIA
I know i'm not a racecar driver but isn't that the way racecar drivers adjust their air pressure?
30 cold is just a generic reading on the door sticker...30 hot has worked for me for years. I have to adjust seasonally to get 30 hot reading/checking ambient temperature frequently.
Bill
St. Jude Donor '11
30 cold on the door isn't a generic setting. It is the pressure you should set the tires so they reach the proper warm temperature. Notice I said warm not hot. Street tires don't see hot temps any where near what a race tire sees. Typical street tire tread temps are in the 130 range while hot race tire tread temps are in the 190 to 220 range. Tire pressure and temperature are linked. The lower the initial cold pressure, the hotter the tire runs which makes the pressure higher. Both temperature and pressure affect tire spring rate which affects handling. They also affect tire grip which also affects handling. The 30 psi setting on the door is for all makes of tires that fit on the Vette.
Bill
Bill
Use whatever pressure gives even tire wear. Even if the sticker on the door says 30psi, when the tires are wearing the centers or edges then it's the wrong pressure.
Trying to keep the "correct" pressure in the tires at all times is impossible. The pressure will vary from a morning drive to one after the car has sat in the sun for a bit. So, do take the ambient temps and tire pressure swings into consideration when setting the pressure.
I'm running wider than stock rubber. In my rears, I run around 28 "cold" in the typical ambient temperature for the season so the pressure typically rises to around 30-31psi when driving. I put ~40k miles on the PS2's I just took off and the wear was very even across the tire surface so it seems to work. It's just an average. The pressure can still vary 3-4 psi day to day but it's not worth chasing day to day.
The previous owner followed the door sticker and wore the centers bald while there was still a fair bit of tread left on each side.
Yello95 (07-09-2021)
