I will be installing an LS6 Manifold, Z06 Air Box with K&N Filter and Corsa Xtreme Cat Back with the XO Pipe this week. The car will then be re-tuned! Looking forward to the gains!
I final got off my butt and did the swap. I put white shoe polish on my coolant lines and sat the LS6 manifold down on it and where I found shoe polish on the bottom of the manifold, I removed the ribs along the path of the coolant lines and that seemed to work just find. The car runs good. The only problem is that it pops back through the exhaust alot worse than it did before. If you have an answer for that, I would appreciate it. Anyway, it wasn't as hard as I thought it would be and appreciate all your help.
If I use the Z06 valley plate, I will have to do some cutting on my block so that's out.
I went to install the ls6 valley cover on my 99 c5 expecting to have to cut my block and my block somehow doesn't have the provision the ls1's did It has 853 heads, had an ls1 manifold, and ls1 PCV. Makes me wonder if one of the previous owners cracked the block? It was stock when I bought it lol
