Which Aftermarket Clutch did you go with?
70k and about to add a NX 100 shot, the time has come for a new clutch.
I wanted to ask which Clutch did you go with, and how much HP are you putting down?
thanks for your help.
Re: Which Aftermarket Clutch did you go with? (NoMercy)
The Star Stage III carbon clutch, Aluminum flywheel, Z06 hydraulics. Will handle over 650 RWHP.
[Modified by HIGHRPM, 1:26 PM 6/27/2002]
DD McLeod w/ Aluminum Flywheel, Adjustable Master, Z06 Slave. HP #'s to be published shortly.
vetterdstr :cheers:
vetterdstr :cheers:
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Re: Which Aftermarket Clutch did you go with? (HIGHRPM)
tThe Star Stage III carbon clutch. Will handle over 650 RWHP.
[Modified by HIGHRPM, 6:56 PM 6/25/2002]
Re: Which Aftermarket Clutch did you go with? (CHRIS NJ C5)
Never burned or used-up a clutch in my 35 year driving carrer. Even on high power vehicles with over 80,000 miles.
Re: Which Aftermarket Clutch did you go with? (MitchAlsup)
for stock power, there is no need for anything more than a stock clutch. but for the power i am looking for, better to replace the part now, then to break it later.
