(C5 Restoration) Remove/clean/paint your door speaker grills, ONE HOUR, $5...........
Old 07-30-2013, 01:26 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
Default (C5 Restoration) Remove/clean/paint your door speaker grills, ONE HOUR, $5...........
I see a lot of C5 speaker grills with some pretty bad foot scuffs or some minor rust/corrosion. It really makes the interior look 'rough'.
The fix:
1. Remove door panels,
x2 T30 Torx screws under pull handle trim
remove door latch handle trim
using door trim removal tool, pry panel from door at x7 retainer pin points
2. Remove speaker grill (Bose/non Bose)
You'll see the speaker panel secured with 8 tabs bent over that fit into slits of the door trim panel
Remove the black fabric along w/ Bose emblem from speaker grill
3. Paint
I use Krylon Fusion 'satin black', you'll want to do a coat or two, spraying it on very lightly as a 18" plus distance, it's easy to clog of the holes of the grill with paint
Very basic "how to", but I think most of you will get the idea, if there are any questions, please post
oktx (12-18-2022)
Old 10-21-2014, 01:11 AM
jose7740
jose7740's Avatar
I am new to the forum and just happened to see this, well I bought my 98 just three weeks ago and one thing it needed was fixing the door panels and of course painting the speaker grilles, just did them today and used a new paint from Krylon (Dual) in gold color and they came out beautiful, will post pictures when the work is completed
Quick Reply: (C5 Restoration) Remove/clean/paint your door speaker grills, ONE HOUR, $5...........
