why the push to solid valves and dual springs?
I'm in the middle of research for heads and cam setups for my ls6 and I keep on seeing head vendors using valve-trains heavier than stock like Solid Valves, Dual springs.
I understand for certain cams specs its necessary to go to duals. But it seems to be go to everyone become burnt on beehive springs (ls6 issues and early comp cams 918)?
What about all this heavy solid valve stuff? I even see the ls7 guys getting pushed to get rid of their Ti valves.
Why would GM go to trouble to put the $ into creating a lighter valve-train unless it help performance or reliability?
Pfadt Race Engineering
888-972-2464
info@pfadtracing.com
Not sure what cam you plan to use, but if I were in your shoes I would have someone very reputable (AI comes to mind) work you 243's and keep the stock valves. Then I would personally install PSI 1500ML and shim accordingly depending on total lift. IMO, the only reason to go to solid valves with your heads is if you went larger. But I would prefer very light with beehives and the largest OD pushrod I could fit.
