"Low Coolant" although it is full ?
I started to get this code a few months ago, I added some coolant and was fine until early this week. I get this code every 5 to 10 minutes. The coolant level is fine, where is the sensor located?
Can anyone offer some advice?
1 Post
Cruise-In II Veteran
Re: "Low Coolant" although it is full ? (John's vette)
The sensor is in the tank. I think there was a TSB out on this that called for just replacing the whole tank. Mine stopped after I bought some goodies from Noel @ AutoBuffs. :)
I just started having the same issue with my sensor. It's located in the rear of the washer bottle. I unplugged mine, and reinserted. After I did that the message disappeared, and hasn't returned in about 24 hours. I will probability go back and give it a good cleaning, since it appears that's were the problem was coming from. Good Luck.
Re: "Low Coolant" although it is full ? (wkasak_98Coupe)
mine used to pop on sometimes when parked on an incline pointing downward. it appears to be very sensitive adding a bit of coolant may solve you problme , it worked for me and you will burn off a bit under normal driving anyhow.
Re: "Low Coolant" although it is full ? (lostsoulny)
I had the same problem as lostsoulny. On a down hill incline the low coolent would come on. Added a little coolant and all is fine! Good Luck on the repair. :cheers:
