Throttle body port and polish now what?
Old 04-17-2018, 09:16 PM
stroker86
stroker86's Avatar
Default Throttle body port and polish now what?
I am taking some time since it's still snowing to tackle some wish list items.
I just ported and polished my throttle body
Now I am going to pull intake to clean oil and build up.
Is there anything else I should be looking at while I have this all apart?
Old 04-18-2018, 07:46 AM
feeder82
feeder82's Avatar
Check the vacuum lines in back of the manifold for cracks while you have that off
Old 04-18-2018, 09:25 AM
v6turbo87
v6turbo87's Avatar
Replace your oil presser sender or put in a relocation kit so the intake will not need to be removed to replace it should it fail in the future.
Old 04-18-2018, 11:35 AM
imgn tht
imgn tht's Avatar
St. Jude Donor '13, '15
Replace the passenger side A.I.R. check valve located behind the intake while the intake is out, or source another drivers side line and reroute to the passenger side.
Old 04-18-2018, 12:01 PM
stroker86
stroker86's Avatar
Thank you all for the info .
I will start getting part numbers together, so i can replace those items.
Old 04-19-2018, 12:53 AM
BigGun
BigGun's Avatar
There are a lot of things you could replace if you just want to spend money.
To Throttle body port and polish now what?
Quick Reply: Throttle body port and polish now what?
