Drive line Shake and rattle when depressing clutch
Hi, I just got a 03 Z06 a little over a month ago. I bought it from California after having it inspected by a 3rd party. I was not all that happy with how much the inspection missed but I still love the Z.
I test drove a few by me before deciding to find one elsewhere with lower miles (51k on the one I bought).
The problem:
After driving it around a while I notice a drive like shake and rattle. I now notice it is mainly in parking lots while driving somewhat slow when I depress the clutch in 1st or 2nd gear. It feels like when the load of the motor is removed by depressing the clutch the transmission shakes a bit. I am assuming there are bad bushings somewhere?
I tried to search and Could not find anything about it. Is this a common problem, is it normal?
It might even be while coasting in 1st then depressing the clutch so the driveline is being torqued in the reverse direction with engine breaking...?
Thanks in advance for all responses.
The problem:
The problem:
The problem:
I also get a small amount of rattle but it almost seems like it is dependent on whether or not the car is warmed up properly before I start driving (especially when it is freezing Temps outsode) so I'm interested to see what people think.
More curious as to what causes it and is it something I need to address before autocrossing. and well If I don't get anything definitive and nothing happens great. If something back there does give out at the track one day, well I guess I will try and keep the thread going if it is just a typical noise.
Link
Check out post 11.
Turning off the rev matching and using the clutch to slow the car a few times cleaned mine up and it is smooth again.
Check out post 11.
Who knows if OP ever got to the bottom of it, but I would've investigated the transmission bushing before digging into the driveline.
Ohh the old related thread "feature:" at the bottom of the page got me.
I need to see about turning that off. It rarely helps out.
