What the hell is column lock?
Old Jul 21, 2002 | 11:35 AM
edv2122's Avatar
edv2122
Default What the hell is column lock?
I have a 2001 vert. I have read so much about column lock. What is it? Should I be on the look out for it in my 01? Any info greatly appreciated! :confused:
Old Jul 21, 2002 | 11:51 AM
wickedvette's Avatar
wickedvette
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: What the hell is column lock? (edv2122)
Colum Lock is - when the solenoid that locks the steering wheel does not retract when the ignition key is inserted leaving the car not driveable. There is an official GM recall for the problem.
Do a search here on the forum for column lock ...and you will find hours of informative reading!
Old Jul 21, 2002 | 11:57 AM
robiferretti's Avatar
robiferretti
Default Re: What the hell is column lock? (wickedvette)
GM build Quality :yesnod: :cheers: :U
Old Jul 21, 2002 | 12:29 PM
kewlbrz's Avatar
kewlbrz
In 2001 they removed the column lock on the Automatic cars and made a shifter lock. But for the 6speeds the problem remained.
Suposedly in 02 they upgraded the column lock to a revised design for the 6speeds. The same one the recall uses.
You can get the bypass which bascially just involves disconnecting the power to the solenoid, and the bypass tells the computer that everything is operating ok so you dont get a code set on the computer.
[Modified by kewlbrz, 10:30 AM 7/21/2002]
Old Jul 21, 2002 | 02:30 PM
Doughan's Avatar
Doughan
Elite Member
If you have a 2001 A4, you don't have to worry about it. If it's a MN6, the potential for failure is there.
:smash: :smash: :smash:
column lock
To What the hell is column lock?
