Hi there,
This code is for the clutch switch circuit. This tells you that the cars PCM is NOT seeing the correct input while the clutch is depressed.
It is located directly beneath the clutch pedal, mounted to the firewall, just below the mounting point.
A simple check, would be to drive with the cruise on, and depress the clutch.
If the switch is working, the cruise control will disengage.
Besttoyou, c4c5 :chevy
