What is my THUMP?
Old Aug 6, 2014 | 10:32 PM
1998BlackPlasticToy's Avatar
1998BlackPlasticToy
Default What is my THUMP?
Last week all of a sudden my car began to make a loud THUMP that can be felt in the seat. Driving along city roads. It's random. Doesn't need to be a bump. My mechanic looked underneath expecting to see a sway bar loose or a shock problem but saw nothing.
A search for "thump" brought up a front differential bushing but turned out that was on a C3. Can't see anything like that on my C5.
Help!!
Old Aug 6, 2014 | 10:52 PM
corvette77's Avatar
corvette77
Does it happen at all speeds? How about while going straight, or turning?
Mine had something that sounds similar, only at low speeds and while turning. It turned out to be a front wheel bearing.
Old Aug 7, 2014 | 08:14 AM
wcsinx's Avatar
wcsinx
Loose sway bar maybe?
Old Aug 7, 2014 | 09:36 AM
KOZ's Avatar
KOZ
The sway bar end links may look and feel tight but I'll bet they aren't. That was my exact problem with the thump!
Old Aug 7, 2014 | 10:56 AM
feeder82's Avatar
feeder82
I had this same problem. Check the sway bars
Old Aug 7, 2014 | 04:29 PM
04tripleblkcoupe's Avatar
04tripleblkcoupe
Also check your cradle bolts after I built my motor mine started to have a pop sound checked sway bar links which was fine then I checked cradle bolts and 2 were loose tightened them no more noise.
Old Aug 7, 2014 | 06:36 PM
1998BlackPlasticToy
I have looked at everything under the car. It was on the lift today for something else. Nothing is loose. However, what ever it was it is no longer thumping!! Go figure. I guess if it starts again, I'll begin my visual search again.
Thanks for all the suggestions.
To What is my THUMP?
