I was sitting in traffic for nearly an hour when the car just died. No spitting no sputtering it just died.
When I key on I can not hear the fuel pump turn on.
Checked all fuses and they are good
I have a racetronics harness.
I have the car on jack stands and I'm testing for power. I have power to the harness from alt and that is good. I unplug the stock harness plug from the pigtail and test that, key on test light turns on for a millisecond then instantly shuts off, this should be staying on once key is on correct? Any suggestions?
How can I test the pump?
Where does the stock harness plug go?
From what I can see there are 4 fuses, 2 under hood and 2 in the footwell, are there any I'm missing?
Where are the stock relays?
i cleared the codes and the car started right up. not sure why going in limp mode would shut power off to the pump but oh well... atleast it was something simple.
The fuse box can get very HOT under extreme conditions. The fuel pump relay works hard and the output contacts could have overheated and starved the pump for current/voltage.
If were me, I would get a new relay and monitor fuse box temps.
You won't get a continues 12v at the pump when you turn the key to the on position you are correct you will see 12v for a split second and that's it. If you want the pump running or want to check voltage without having to read a volt meter and turn key on this is what you do. Make a jumper wire with long end contact that can do deep enough into the pins that the relay goes into..Go to the fuel pump relay pull it out looking down on it from the passenger side you want to jump the upper left and lower right together of that relay. Put the key in the on position and the pump will continue to run or you can check voltage without it going to zero.
i ended up figuring out what the problem was.... i found a "homemade" connector one of the shops i brought the car to from the racetronixs harness to the stock fuel pump wire, seems they soldered the contacts and the joints were broken. im going to replace the homemade connector with some good weather tight connectors and be on my way.
