Traction control/ABS/Active Handling/Air Conditioning
Cruising
Hey guy,
Need some help. I have a problem with my 2002 Z06 and cant find a real answer from anyone. Figured i would check with y'all.
There are times I will start my car up and the Traction Control/ABS/Active handling service lights will come on. When I first start it up and those lights come on the A/C wont kick on.
Now after 30 sec up to about 4 mins (anytime in between there) the car will chime at me and the abs light will go off but the Traction control light will stay on. It will come up in the DIC again and say service TC service AH. I cleared all the codes in my DIC hoping that a lot of the H codes would go away and I could get a more accurate code for what the problem is. The codes that came back that i pulled this morning are P1571 C1277 B0432 U1040 And B2265.
When i bought the car the guy told me it had been doing this same problem off and on. he said he had his "mechanic" look at it and he said it was just the traction control module. I dont know that this is not the answer but it seems more than that. Any info or help is appreciated.
Cruising
I suggest that you again clear ALL the codes and then take the car for a ride. When you return pull ALL the codes BEFORE you turn off the ignition. To pull codes with the engine running you may need to press the reset button to clear messages that show in the DIC and then pull codes as normal.
Post ALL the codes including the H or C or HC that follow each code.
If there are any Uxxxx codes, list them UNDER the sensor that they are associated with. Many Uxxxx codes can appear under more than one sensor and it can make a difference which sensor experiences the Uxxxx code.
Cruising
Cruising
Okay its been a few days now. but I finally got all the codes to clear and i documented all the codes that were there, then cleared the codes and drove it about 30 miles and doc all the codes that came back right away.
The codes that were on the car before i went a drove:
P0135 C. P0155 C. P0420 H C. P0430 H C. P1571 HC. P1689 H C. B0432 H C. U1040 H C. U1160 H C. U1040 H. B 2265 H.
the codes that came back after the 30 mile drive:
P1571 H. P1689H. C1277 H. B0432HC. U 1040H.
Any help would be greatly appreciated.
Andy
Andy
Gasoline Addict
Same prob.
Hey guy,
I sprayed wd 40 in the ignition switch today. It hasn't done it anymore yet
