Gas cap wont work
Old Nov 9, 2014 | 10:46 PM
dbvettez06's Avatar
dbvettez06
Default Gas cap wont work
Any ideas on how to fix this problem?
Old Nov 10, 2014 | 12:27 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Meaning what exactly? Gas cap won't stay on tight? Won't screw on correctly? Is it the original or replacement?
Old Nov 10, 2014 | 12:47 AM
ETPhoneHome's Avatar
ETPhoneHome
lol op i am not sure how you can be any more vague. what is your problem?
Old Nov 10, 2014 | 05:51 AM
SG Lou's Avatar
SG Lou
Replace it.....Common problem not with just C5's..Do a Google search for
Chevy Gas Caps and you'll see ! Fairly cheap to replace....I just replaced mine this past summer because it wouldn't stay closed and locked.
Old Nov 10, 2014 | 04:36 PM
RedZMonte's Avatar
RedZMonte
Rock auto sells a Delco (OEM) cap with leash that works perfect. mine failed Emissions test for leaky cap, swapped this on and no problems.
Old Nov 11, 2014 | 06:02 AM
SG Lou's Avatar
SG Lou
For what they cost you're better off replacing
Old Nov 11, 2014 | 09:49 AM
dbvettez06's Avatar
dbvettez06
SO sorry some days my brain is on r&r.....When i push the button to open the gas cap door, it wont open i have to open it from inside the trunk...
Old Nov 11, 2014 | 01:58 PM
SG Lou's Avatar
SG Lou
Ohhhhhhhhhhhhh That's an entirely different story.
Mine was sticking so i sprayed some WD-40 into the mechanism and it freed it up...been good ever since.
Old Nov 11, 2014 | 02:29 PM
Corvette_Ed's Avatar
Corvette_Ed
Did you pull out the center console to make sure the plug for the gas door button was connected solidly?
Old Nov 13, 2014 | 10:49 AM
dbvettez06's Avatar
dbvettez06
No but i will try that...Could there be a fuse involved? I cannot find one for the gas release for the tank...
Old Nov 13, 2014 | 11:25 AM
Corvette_Ed
The fuse is labeled as the fuel door. Fuse 32 according to this thread:
https://www.corvetteforum.com/forums...box-local.html
To Gas cap wont work
