High flow catalytic converters
Old Jan 18, 2015 | 10:20 PM
rickw99vette's Avatar
rickw99vette
Default High flow catalytic converters
I recently bought a couple of high flow catalytic converters for my C5. Took them to a local muffler shop to have them installed. The owner of the shop said if he replaced them the check engine light would probably stay on and he also said the small converters from the factory were high flow anyway. Is this true or do I have a shop that just didn't want to change them ? Second if I change them will check engine light stay on? It looked to me the sensors would be behind the converters.
Old Jan 18, 2015 | 11:21 PM
dblerman's Avatar
dblerman
Unless you had a problem with the factory cats, there is really no reason to install high flow cats. Just a waste of money in my opinion.
The rear O2 sensors just tell the computer whether or not the cats are functioning. Some of the cheaper aftermarket high flow cats cause a check engine light, some don't. You can have the rear O2 sensors tuned out if you get a light.
Old Jan 18, 2015 | 11:46 PM
rickw99vette
Thanks for info.
Old Jan 19, 2015 | 12:24 AM
grantv's Avatar
grantv
Everything I've read indicates the stock converters will not be a bottleneck, even with headers and loads of power. That said I'm installing headers right now and if I run cats (haven't decided 100% yet but my conscience is telling me to), I will replace mine with new "hi-flow" units as one of mine is discolored (indicating an issue). And I was getting a code on that same side before I pulled the car for the winter.
Old Jan 19, 2015 | 12:38 AM
rickw99vette
A few years ago I removed the cats on a 99 coupe I use to owned, Made the car much louder which I liked but I got a lot of exhaust smell inside the car so I put them back on. Have you ever had that problem?
Old Jan 19, 2015 | 12:48 AM
grantv's Avatar
grantv
Had, no, heard tons about, yep. There is only one reason I would consider not running cats; $. But I'll probably do the right thing. No checks of any sort in this part of Canada, it's a conscience thing only.
Old Jan 19, 2015 | 03:11 AM
StingrayRebel's Avatar
StingrayRebel
or if you go forced induction... those cars tend to run on the rich side and can burn the cats out... personally I don't mind the smell and like the sound increase
Old Jan 19, 2015 | 08:42 AM
Rx7Rob's Avatar
Rx7Rob
Really????? On my 2000 removing the cats (all four) barely changed the volume. It made the tone a little deeper but not much louder. Sounded more like I would have expected from the factory.
Old Jan 19, 2015 | 10:33 AM
grantv's Avatar
grantv
I meant me, personally, pretty much guaranteed I'll never go FI. But absolutely, yes, maybe I should have been more clear; with my car plans the only reason....
Old Jan 20, 2015 | 03:12 PM
Brock63's Avatar
Brock63
only way you should get fumes in car is if the tail pipes are not clearing properly to pull fumes behind car or you got a leak after the headers somewhere......cat should not influence that one bit...faulty install or removal can though.
Old Jan 20, 2015 | 03:34 PM
Rob Petyo's Avatar
Rob Petyo
I haven't done that search but I run a H/C/I setup that runs low 10's. Was running the 2 1/2" "hi-flow" cats in the ARH X-pipe but have recently gone to a 3" (no cat) pipe from the headers and yes my sensors are turned off ... haven't noticed much difference in power yet but at the level of mine it's "every little bit adds up" I have not dyno'd yet so any gain will have to be in ET.
It is LOUD
To High flow catalytic converters
