C5 2003 Ball Joints Check
Old Jun 12, 2015 | 12:44 PM
BIGJIM13's Avatar
BIGJIM13
Default C5 2003 Ball Joints Check
Guys
any links on how to check front end ball joints on a 2003?
Old Jun 13, 2015 | 11:10 PM
TastyBacon's Avatar
TastyBacon
Besides taking the front end apart and wiggling 'em with your fingers? Not that I know of.
Old Jun 14, 2015 | 08:18 AM
SG Lou's Avatar
SG Lou
Years ago.....I mean MANY years ago the norm was to jack the side up of the front end in question, grab the top and bottom of the tire and rock it back and forth to feel for any excessive movement.
It's worth a try.
On the flip side: I rebuilt my front and rear suspension a few years ago and had no idea my ball joints were bad until i had things apart.
Old Jun 15, 2015 | 12:13 PM
TastyBacon's Avatar
TastyBacon
Right. In my experience, you can have ball joints that are pretty loose and you won't be able to tell by wiggling the tire; you have to pull the spindle.
Old Jun 15, 2015 | 05:07 PM
goombadi99's Avatar
goombadi99
Place a jack under the lower arm you want to check. You have to pre load them this way in order to check for play.
Old Jun 15, 2015 | 08:59 PM
Boss75's Avatar
Boss75
Jack up the front and/or rear end. Get enough ground clearance where a big pry bar can slide under the tire. Pry up against the tire from the ground and check for any type of movement up and down. Now place one hand at the top of the tire and one hand at the bottom. Push in and pull out with each arm to check side to side movement.
If you have a ball joint moving but can't tell which one get a friend to look while you do this. If you can only feel the movement and not see it, put a hand on the knuckle and the ball joint and try and feel which one is moving.
To C5 2003 Ball Joints Check
