Parasitic battery draw
Old Jun 30, 2015 | 01:42 PM
HT99's Avatar
HT99
Default Parasitic battery draw
Trying to troubleshoot a parasitic battery draw.
I have a 1.7 amp draw when I initially apply the meter (set at 20 amps) leads to the battery terminal. After 30 seconds it drops to ~0.9 amp draw.
Pulled all the fuses in the engine bay, no difference.
Unplugged the alternator, no difference.
Lower passenger side fuse box, pulled Fan blower fuse and the draw dropped to ~0.6 amp, still high. Haven't finished pulling all the fuses yet.
Is there a way to disable the interior courtesy lamps when I open the door? I've been disconnecting the meter, pulling the fuse, closing the door, reconnect meter to avoid the amp spike from the courtesy lamp draw.
Old Jun 30, 2015 | 01:55 PM
Trios's Avatar
Trios
I don't think the courtesy lamps will spike 20 amps through your meter. However, you could just pull the courtesy lamp fuse, should be minifuse 29 unless that changes over the years (the better electrical gurus will chime in and correct me).
EDIT: You may want to pull microrelay 42 instead, as pulling fuse 29 will drop other loads as well and that might not be what you want when you're trying to track the draw.
Old Jun 30, 2015 | 02:32 PM
HT99's Avatar
HT99
The lamp spike will go to 4-5 amps.
The meter is set to handle up to 20 amps.
Pulled micro relay 42 and then fuse 29, lights don't go on but still got the 4-5 amp spike.
Picture of fuse layout, any other suggestions?
Old Jun 30, 2015 | 03:46 PM
Trios's Avatar
Trios
Uh, suggestions for what?
I thought you were asking how to shut off the lamps so you could set up the meter and then get in the car to start pulling more fuses. So, do that. Set up the meter, put it on the windscreen where you can see it from inside the car, get in, close the door, wait for current to drop (can take a few minutes) and then start pulling fuses to see which one is your major current draw.
Old Jun 30, 2015 | 05:08 PM
LoneStarFRC's Avatar
LoneStarFRC
Couldn't you just temporarily remove both of the the B+ cables from the U/H fuse box, and re-connect them together to each other with a bolt/nut, then disconnect the B+ cable where it connects to the interior fuse box, and insert your DVOM in series at that location?
That way you've isolated the U/H fuse box plus have the DVOM inside the car where you're working.
Old Jun 30, 2015 | 05:24 PM
HT99's Avatar
HT99
I can't shut the door and be able to reach underneath to pull fuses
What I didn't try was pulling the fuse/relay and wait a few minutes to see if the 4-5 amp spike drops. I think the open door shouldn't matter at this point unless their is a Door Control Module (DCM) sending signal to the Body Control Module (BCM)....I'll try it out
Old Jun 30, 2015 | 05:27 PM
HT99's Avatar
HT99
Hmmm, could this work with the B- cable?
It reduces the risk of shorting something out.
Old Jun 30, 2015 | 05:59 PM
Trios's Avatar
Trios
Nah, this won't work with the negative side. He's talking about removing the power source from the fuse block and running the underhood fuse block (and only the underhood fuse block) out of your DMM. You've already isolated that the problem isn't in the underhood fuse block, so I don't know what the purpose would be.
Sorry about the suggestion to close the door, then. I'm a small guy, so I didn't really think about that being a problem. I don't know how to continue troubleshooting without closing the door, though; I'm certain there's lots of things the BCM does when the door is open other than just turn on the lights, and it'll affect your readings.
Maybe ask a smaller friend or family member to crawl in there head first and close the door on them?
Old Jun 30, 2015 | 08:47 PM
4DRUSH's Avatar
4DRUSH
I use a screwdriver to close the door latches in the door, the car thinks the doors are closed.
Don't forgot to undo the latch before closing.
Check the car in total darkness, could be an interior light not turning off
Old Jul 1, 2015 | 03:38 AM
LoneStarFRC
I'm not speaking about diagnosing the U/H fuse panel (or any of it's circuits), rather I'm talking about eliminating it from being in the circuit(s) being tested altogether and at the same time being able to locate and connect the DVOM inside the car instead of under the hood. The battery itself would remain connected as normal.
Since the OP is too big to work inside the car without the door being open it may be a moot point, so........
To Parasitic battery draw
