How do I break 500???
btw, its not the rotating assembly that would be in trouble at 8000 rpm, its the valvetrain.
Callaway intake
100mm MAF
NW 102
Fast 102
56# injectors
OE rotating assy
PRC stage 2.5 heads
288/291 .605/.610 111LSA cam
Johnson short travels
Yella Terra Roller rockers
3/8" pushrods
1-3/4" LT's
high flow catted X
Borla stingers
graph was still climbing at 7k - barely, but was climbing...
Any ideas? I'm thinking about doing a forged rotating assy to spin to 7400-7500 and also bumping the compression when I do so by fly-cutting the pistons and having heads decked a bit...
the cam isnt even a "max effort" cam? an MS3 and MS4 are still bigger...? BUT they usually dont have the intake setup I have this big?
Cam specs: 235/240 @ .050" and .629"/.615" with a 111 LSA (wasnt exact on the lift #'s)
So sounds like I need to order some 1-7/8" headers...?
As for the drivability - I know people run more cam than this and still can drive the car. Mine if you slow down to a stop then the R's drop and kill it OR it will almost die, bounce up and the oscillate until it dies or settles out after a few bounces of the tach...
Machinist and I were talking last night and he thinks its the exhaust that's 'backing it up' and killing it or making it want to die. I do have a nice edge on the head-to-primary runner joint to help stop the shockwave from coming back up the header and pushing exhaust into the intake, but I think you may be right that it isnt enough area for the exhaust ot escape in time...
I have a REALLY REALLY open intake setup and a really open exhaust... obviously the restriction point will cause an upstream backup... next questions... I have 30 days to fix this issue and get the car ACTUALLY tuned... will ARH or LG super pro LT's bolt upto my TSP x-pipe...
Callaway intake
100mm MAF
NW 102
Fast 102
56# injectors
OE rotating assy
PRC stage 2.5 heads
3/8" pushrods
1-3/4" LT's
high flow catted X
Borla stingers
Is the 102 ported? What clutch are you running? What wheels/tires and breaks are you running? I don't see and electric water pump or underdrive pulley listed. You can get a turn one power steering pump as well. You can hit 500 easy
the 102 is ported yes - took out a chit load in the ports to get them to even be close to the head size.
clutch is a light weight FW, and a 9" road race setup. about overall 35% less inertia for the PP+FW+discs compared to OE
No electric water pump yet
DO have an underdrive pulley on it
NO PS pump mods - just OE
Was saving all those for next season to hopefully put me in the 520-530 range...
Trying to prove a point on this build...but not doing so well yet. lol
But yes, there are a lot of things I can do to hit 500 from here and for sure after this season I will easily jump over that mark. I'm just trying to see with my current setup what the limiting factor is. which seems like it might be rockers and header primary size.
really wondering now if the headers are the issue with the drivability deal...
Callaway intake
100mm MAF
NW 102
Fast 102
56# injectors
OE rotating assy
PRC stage 2.5 heads
3/8" pushrods
1-3/4" LT's
high flow catted X
Borla stingers
Personally if youre going to do a bottom end stroke it get Mamo to do some heads up for ya and a mildish solid roller youll be well over the 500 mark and can still cruise it on the st.
His 383 was pretty impressive- Lotsa ways to skin a cat
The 3/4 primaries and cats are robbing some low hanging fruit though.
If your car dies at idle you also have tune issues. The combo of FAST 102, NW 102, 100mm MAF, fairly big cam and lightweight clutch and FW are a challenge to tune....those will take time to get exactly right.
Of course there's always the Freevalve option..
