Heat &I Sound insulation install
Haven't started yet but acquiring what I need. What is the tool called for removing door trim? A pic might help. Anything else I should get that is not an ordinary tool? Thanks
Thanks, I'll ask a friend who used to do body work if there is anything special or different for the Corvette. Nothing I hate worse than to go into any kind of store and not know the proper name for something I want to buy.
Check Amazon for Astro 4524 Auto Fastener and Molding Removal Tool Set, 11-Piece; I bought this set 2-3 years ago for a similar project to what you're planning. It's inexpensive, has pretty much every tool you'll need, and it's good quality.
The following 2 users liked this post by Mickeyrx70:
Awkwardcrane (03-10-2016),
ewf3 (10-28-2022)
Much appreciated, I just got the insulation kit and now waiting for Dr. to allow me to....do anything. Had 4 vertebrae in my neck fused and itching to get going on the car.
Received 1,090 Likes
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I used this set from Harbor Freight. Worked fine.
http://www.harborfreight.com/nylon-p...-pc-69668.html
Might be good idea to grab a couple door pins just in case!
Awkwardcrane (03-11-2016)
Thank you very much. That saves me a lot of time. On the other hand doc says 6 more weeks with neck brace and lift no more than 5 lbs. so I have some to to prepare.
