What is this relay for on my ignition
Old 03-26-2016, 12:53 PM
tazelsolari
3rd Gear
tazelsolari's Avatar
Default What is this relay for on my ignition
So I finally decided to install an aftermarket radio into my car and that's when I found something that I don't know what it is.
The yellow ignition wire is cut and then both ends go to to the relay (red and blue wire on the relay). From there the white wire is used and feeds to a fuse that goes into a red wire in a wire harness under the steering column.
From the red wire with the fuse it then goes yellow wire that runs into the box thing. There's also a black wire that serves as ground to power the box. The box flashes green and red alternating.
At first I thought it was a column lock bypass but from all the googling I've done I'm not sure if this is indeed the case or not.
So I'm hoping someone can help me get to the bottom of this.
Old 03-26-2016, 10:57 PM
SilverC54me
SilverC54me's Avatar
That's some kind of aftermarket alarm with imobilizer or ignition kill switch.
I am not a fan of three devices and from the pictures it looks like a poor install. Carefully surgery will be needed to remove it.
It does look like you can splice the yellow wire at the ignition switch back together easily. The rest will require carefully tracing the wires.
If you are in Southern California let me know, I can help with the removal.
Gary
Old 03-27-2016, 10:31 AM
tazelsolari
3rd Gear
SilverC54me thanks for your reply.
I did some more digging and taking apart and it looks like I know what it is now. It looks to be some sort of GPS tracking device from googling the part numbers.
I traced each wire to see where they went to and then resoldered and heat shrinked each connection. Car is still running so I'm good to go.
Old 03-28-2016, 12:15 PM
0Liveviewgps
Former Vendor
Liveviewgps's Avatar
That is definitely a GPS tracker, the SIM (yellow card), is used to transmit wireless data from the device to a backend server. The brown square looking piece is the gps receiver antenna. The relay, is more than likely connected to an output on the GPS device, that would allow the user to send a command to the device that triggers the relay. Probably used as a starter disable...
Old 03-28-2016, 12:32 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
DAMNIT Now the FBI doesn't know where your at and how fast your going!
Old 03-28-2016, 01:32 PM
feeder82
feeder82's Avatar
that a Lojak?
Old 03-28-2016, 03:06 PM
0Liveviewgps
Former Vendor
Originally Posted by feeder82
This that a Lojak?
No, its an older model run of the mill gps tracking device.
Old 03-29-2016, 02:34 PM
mrlmd
mrlmd's Avatar
Probably installed by the PO's wife.
Or yours!
To What is this relay for on my ignition
Quick Reply: What is this relay for on my ignition
