Trailblazer SS intake manifold
Does anyone know first hand how much taller a TBSS intake is compared to the LS6?
I have a raised hood but would like to avoid buying it to find out if it'll fit.
Sorry for the 2&1/2 year bump, but this needs to be corrected and I also would like to hear feedback on TBSS intake on a C5.
http://www.mrk-motorsports.com/20-po...s-dyno-tested/
"Stock Trail Blazer SS
eBay Price: $210
Construction: Composite
Runner Length: 9.5 in
Throttle Opening: 3.45 in
Throttle-Body Size Tested: FAST 90 mm
Fuel Rail: FAST (modified mounts)
Injectors: Holley 75 lb
Peak Power: 562 hp at 7,000 rpm
Peak Torque: 497 lb-ft at 5,000 rpm
Ave HP (3,000–7,000): 444.4 hp
Ave TQ (3,000–7,000): 464.6 lb-ft
TQ at 4,000 RPM: 469.5 lb-ft
What We Like: Bigger throttle opening and best overall factory performer
What We Don’t: Limited availability and even more expensive than the LS6"
eBay Price: $210
It will not fit under the cowl. The intake is the best of the OEM cathedral port intakes. If you are willing to cut the cowl, it might fit with the modifications required to fit a Hi Ram in a C5
https://www.corvetteforum.com/forums...cai-ideas.html
I would save my money on the hood and get a FAST 92 or 102.
VFR RC46 (01-15-2019)
Thank you sir. Much appreciated.
I have read somewhere that the LS6 intake is about 6-1/4" tall. Here is some info here on the much taller TBSS manifold;
https://www.ls1gto.com/forums/showthread.php?t=815745
