Correct way to change crank pulley
My crank pulley bolt keep getting loose after oil pump swap.
Is this procedure correct.
INSTALLING A NEW PULLEY.
1.Seat it between .096-.176in on crank snout
2.Use old bolt to make sure it's seated properly by torquing to 240lb-ft,measure depth again.
3.Put new bolt,torque to 37lb-ft
4.Turn 140 degrees.
4.Turn 140 degrees.
Chatmove (04-18-2016)
Received 1,260 Likes
arp bolt and pin the balancer to the crank, after that it should never come loose
arp is a more straightforward process, just torque it and be done... you don't have to torque it and stretch it "x" degrees like the stock bolt... I'm not sure of the exact torque number but it should be included with the bolt
If you properly installed the balancer and bolt and it still came loose then I would be pinning the balancer when I put the new bolt in. The most likely cause of a properly installed balancer and bolt coming loose is not having the proper interference fit.
EDIT
Called my local speed shop and they said ARP pulley bolt is back order till May 5th so I'm going the OEM way...
I have no angle meter can some1 tell me a good way to measure 140 degrees(where to mark,etc)
Thanks everyone.
When I re-installed it after the oil pump swap,I didn't measured the depth,put a new bolt and used an impact to tighten it...Rookie mistake I know.I'm pretty sure I have NOT damaged the thread because it still took quite a while before it got loose.
EDIT
Thanks everyone.
EDIT
Thanks everyone.
You could have posted you didn't install it right the first time.
Anyways, if the bolt came loose and the damper has spun on the crank then the interference fit is definitely screwed up so I would pin it for sure. Make sure it does fit tight on the crank.
It is a lot of torque. I did the 140deg method and I had to use my jack stand handle on a breaker bar to get it that tight.
If you try to use a good torque wrench that only goes to 250 you may trash it. Be careful.
Pull down on the wrench handle until it lines up on your imaginary clock face between 4 and 5 o clock. That "should" put you in the ball park.
Or you can purchase on of these :
http://www.nationaltoolwarehouse.com...80caAmCn8P8HAQ
BTW: look at the dial face on the picture and see where 140 degrees falls.....between the 4 and 5 o clock position
How did you press on the new balancer? Hope you didn't pull it on with a bolt, a.k.a., ls1howto.com
This is correct. That assembly is likely toast without a pin. Also, if you go ARP, then the ARP bolt is installed after tightening the old bolt to 240 lb-ft, not before. It's installation replaces the new GM bolt step of the installation.
