4l60e stage 5 not going into 4th/OD
I recently blew out my flexplate. In the process stretched my tranny cable. My car has very odd quirks. Like when it first starts up it NEEDS to be left in park until up to operaterting temp or it'll stall right out. 408 stroker with giant cam. Well I tried rigging the cable back up and had a hard time but I thought I had it.. Park is park reverse is reverse and neutral and drive are neutral and I THOUGHT 3rd was drive... well let's start here. Went to fire the car up. And it kept stalling out like it was in gear but key came in and and out until I slammed the shifter as hard forward as I could it warmed up as normal. Pulled out of driveway finding my so called drive took about a minute while sitting in the road. Car seemed to run fine. Was going about 70mph and matted it. Car got to about 95mph and bounced off the rpms at 6500 and I let right off and it didn't go into neutral it just wasn't even attempting to shift.. making me think it wasn't in drive but actually 3rd and I missed drive compeltely while doing the rig of a job while waiting to find a cable.. i am down about a quart and a half of trsnny fluid because i did this whole job on a unleveld driveway on jackstands. So getting fluid in a tilting tranny=impossible. but my question is do these trannys shift normal but not go higher then 3rd when driving around in 3rd? This would end my suspision. Because it not being fully engaged in park "I think" for warned me this cruise wasn't going to go well.. does this sound accurate? I'm thinking of just installing a old-school slam shifter in it since I'm going to be taking the whole damn thing apart anyway. Deciding if I should just keep it as is aND replace stock broken cable or just go for a slam shifter. I'm getting tired of the *** end coming out not knowing if it's going to go in 1st or 2nd when I mat it. It's getting dangerous but I'm not seeing anyone installing these in these cars. My stage 5 trans is setup for a shift kit
The cable and cable geometry is crucial to this transmission. If it is stretched, replace it. The cable controls the line pressure in your trans and if the pressure is to high or to low it will never work properly. Use an OEM bracket and make sure the fluid level is full. Low fluid also causes shifting issues.
Also, you can eliminate any electronic issue by verifying the computer is commanding 4th gear. You would need a good scan tool or TranX to verify command. If the computer doesn't command 4th, it will never shift.
The cable just needs to get it to the proper gear detent.
If you leaving the shifter in 3rd and not drive it will not go into overdrive. As far as acting funny while shifting my car was about a quart low on trans fluid once and it was very lazy and didn't want to shift, I had to let out for it to go into overdrive and if I was on a hill it would go in and out of overdrive. I'm assuming that's because it had just enough fluid to go into overdrive but not stay. Just my experience.
A rachet shifter in a C5? The only one I've ever heard of in a street driven car was done by England Green back in 2006. https://www.corvetteforum.com/forums...up-no-way.html I would be very interested in a rachet shifter also but it was a VERY difficult job and required lots of BBB (Big Brass *****) as there were permanent modifications that were required along with some welding skills.
If you indeed are going to do this, would you mind taking some pics as you go along so the rest of us might have an idea how hard or easy it is? I suppose its possible someone has now come out with an easy to use kit which would be great, but I'm not aware of it. Please share info... Thanks
The interior I didn't have to cut at all. It was the floorboard because the cable is now looped instead of a straight unit. So it needed to fit and it was tight up towards the center console so had to do some the fabbing. Bezel I don't think I touched
