Service Charging System
Old Jun 10, 2016 | 10:33 AM
codyc24's Avatar
codyc24
Default Service Charging System
We have a 98 C5 corvette. We have replaced alternator and battery with gm parts. Soon as you start the vehicle it displays "service charging system" clear the message and drive, about 10-15 minutes into driving it, it will display the same message ago. Everything from the alternator and battery test perfect in range even when the message was displayed. Any known issues with this for the C5's? Any help is greatly appreciated. Thanks!
Old Jun 10, 2016 | 10:43 AM
Macleod52's Avatar
Macleod52
Very well known issue. Lots of threads discussing it. Hopefully you can get your core back from where you purchased your alternator. It's best to have the alternator rebuilt rather than replaced due to this issue.
Dreaded Charge system Fault alert showed up Posts #14 & #16 have some good insight into the charging system.
Old Jun 10, 2016 | 10:45 AM
73Corvette's Avatar
73Corvette
Wrong alternator
https://www.corvetteforum.com/forums...nd-issues.html
Old Jun 10, 2016 | 11:29 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
this happens so much, if you all just did some research here first, save many headaches !!!
To Service Charging System
